[Geoserver-devel] Error building with Maven2
When trying to build GeoServer I get the following error. It's trying to
download the file from mortbay.org but the site seems to be down. I searched
for all mention of mortbay.org and switched them to other locations and it
actually got past this error, but then failed it failed some tests! This is
the first time I've tried to build GeoServer so please be patient with my
stupidity.
Jon
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO] Error building POM (may not be this project's POM).
Project ID: org.apache.maven.surefire:surefire-booter
Reason: Error getting POM for 'org.apache.maven.surefire:surefire-booter'
from the repository: Error
transferring file
  org.apache.maven.surefire:surefire-booter:pom:2.3
from the specified remote repositories:
  codehaus-snapshot-plugins (http://snapshots.repository.codehaus.org/),
  apache.snapshots (http://people.apache.org/repo/m2-snapshot-repository),
  central (http://repo1.maven.org/maven2),
  mortbay-repo (http://www.mortbay.org/maven2/snapshot)
[INFO]
[INFO]
[INFO] Total time: 12 seconds
[INFO] Finished at: Tue Aug 28 17:38:19 BST 2007
[INFO] Final Memory: 12M/22M
[INFO]
View this message in context: http://www.nabble.com/Error-building-with-Maven2-tf4342829.html#a12371541
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
dead passive ha scritto:
stupidity.
Jon
[INFO]
[ERROR] BUILD ERROR
[INFO]
transferring file
Hum, that jar should be on central, so I guess central is gone
bye bye for today (unfortunately it's not that reliable).
I suggest you setup maven mirrors so that when central does not answer
other more reliable (and possibly faster) sites may kick in.
You can find a guide here:
http://maven.apache.org/guides/mini/guide-mirror-settings.html
