[Geoserver-devel] Error compiling the GeoXACML comunity module
Hello,
I’m participating in a project where we would like to use the funcionality offer by the GeoXACML comunity module, and after a several tries with Eclipse or Netbeans I didn’t manage to build your project.
It would be very helpful for our project, any orientation about how proceed in orden to build-compile your source code.
Below you can find information about my system and the error message I got:
Operating System: Ubuntu 13.04
java version “1.7.0_45”
Java™ SE Runtime Environment (build 1.7.0_45-b18)
Java HotSpot™ 64-Bit Server VM (build 24.45-b08, mixed mode)
NetBeans IDE 7.1
Eclipse Java EE IDE for Web Developers.
Version: Kepler Service Release 1
Build id: 20130919-0819
I downloaded the latest stable source code from your site, the: “Geoserver 2.4.2” version, and I also tried with the trunk source according to your readme file, and when I executed a “mvn clean install” or a “mvn install” command I got the error:
zequeira@anonymised.com9…:~/eclipse/workspace/trunk/src/community/geoxacml$ mvn clean install
[INFO] Scanning for projects…
[ERROR] The build could not read 1 project → [Help 1]
[ERROR]
[ERROR] The project org.geoserver:geoxacml:1.0 (/home/zequeira/eclipse/workspace/trunk/src/community/geoxacml/pom.xml) has 1 error
[ERROR] ‘dependencies.dependency.version’ for org.springframework.security:spring-security-core:jar:tests is missing. @ line 58, column 17
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
zequeira@anonymised.com:~/eclipse/workspace/trunk/src/community/geoxacml$
Rafael Zequeira
Hi Rafa
The geoxacml module is out of support. You can get rid if the error if you uncomment the following section in the pom.xml
Unfortunately, the module does still not compile.
Christian
On Wed, Dec 11, 2013 at 10:26 AM, Rafa Zequeira <rafazj@anonymised.com> wrote:
Hello,
NetBeans IDE 7.1
[ERROR]
[ERROR]
[ERROR]
Rafael Zequeira
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
