[Geoserver-devel] Error deploying Nighly Geoserver war build in Tomcat 7
Getting the following error when I try to access the geoserver admin page (http://localhost:8080/geoserver).I.I) have deployed the latest nightly build war file in Tomcat 7 on
Windows server. The error stack trace is as follows
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Filter execution threw an exception
	org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
	org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
	org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
	org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
	org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
	org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
	org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
	org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
	org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
	org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
	org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
	org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
	org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
	org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
	org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
	org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
	org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
	org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
root cause
java.lang.AbstractMethodError
note The full stack trace of the root cause is available in the Apache Tomcat/7.0.0 logs.
Apache Tomcat/7.0.0
Thanks and Warm Regards
Debasish Sahu
Odd... i have not tried out geoserver on tomcat 7 yet... but I wonder if the filter api has changed in any way. Or perhaps there are multiple copies of the servlet api around... something worth more investigation. My bet would be there would be problems with tomcat 6.
On 10-07-27 9:09 PM, Debasish Sahu wrote:
page (http://localhost:8080/geoserver).I have deployed the latest
  HTTP Status 500 -
*type* Exception report
*message* __
*description* _The server encountered an internal error () that
prevented it from fulfilling this request._
*exception*
*root cause*
*note* _The full stack trace of the root cause is available in the
Apache Tomcat/7.0.0 logs._
      Apache Tomcat/7.0.0
Debasish Sahu
The Palm PDK Hot Apps Program offers developers who use the
Plug-In Development Kit to bring their C/C++ apps to Palm for a share
of $1 Million in cash or HP Products. Visit us here for more details:
http://ad.doubleclick.net/clk;226879339;13503038;l?
http://clk.atdmt.com/CRS/go/247765532/direct/01/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I am using geoserver with tomcat 7, but not the same nightly build used here… It would be easy to debug, if we can get geoserver logs for reason
regards
Senthil
On Tue, Aug 3, 2010 at 12:44 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Odd… i have not tried out geoserver on tomcat 7 yet… but I wonder if
copies of the servlet api around… something worth more investigation.
HTTP Status 500 -
message __
exception
root cause
Apache Tomcat/7.0.0
Debasish Sahu
Justin Deoliveira
http://p.sf.net/sfu/dev2dev-palm
