[Geoserver-devel] error in compiling geoserver.war
I have psql 7.2.3 with postgis 0.7.5 and jdk 1.3.1_07.
Under the geoserver root directory, I typed ant test-ext (I also tried ant war) and I got this error message :
Buildfile: build.xml
init:
all:
[javac] Compiling 72 source files to /tmp/geoserver/build
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/ConfigInfo.java:10: cannot resolve symbol
[javac] symbol : class Logger
[javac] location: package logging
[javac] import java.util.logging.Logger;
[javac] ^
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/ConfigInfo.java:11: cannot resolve symbol
[javac] symbol : class Level
[javac] import java.util.logging.Level;
[javac] ^
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/ConfigInfo.java:30: cannot resolve symbol
[javac] location: class org.vfny.geoserver.config.ConfigInfo
[javac] private static Logger LOG = Logger.getLogger(“org.vfny.geoserver.config”);
[javac] ^
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/ServiceConfig.java:11: cannot resolve symbol
[javac] ^
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/WfsConfig.java:11: cannot resolve symbol
[javac] ^
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/WfsConfig.java:12: cannot resolve symbol
[javac] ^
[javac] /tmp/geoserver/src/org/vfny/geoserver/config/WfsConfig.java:31: cannot access org.geotools.resources.Geotools
[javac] bad class file: /tmp/geoserver/lib/geotools.jar(org/geotools/resources/Geotools.class)
[javac] class file has wrong version 48.0, should be 47.0
[javac] Please remove or make sure it appears in the correct subdirectory of the classpath.
[javac] import org.geotools.resources.Geotools;
[javac] ^
[javac] Note: Some input files use or override a deprecated API.
[javac] Note: Recompile with -deprecation for details.
[javac] 7 errors
BUILD FAILED
file:/tmp/geoserver/build.xml:161: Compile failed; see the compiler error output for details.
Total time: 15 seconds
What am I doing wrong ? Could you help me, please ?
Thanks
Paul
The problem is that you need java 1.4, as we are using the built-in java
logger of that release. So the easiest thing to do is upgrade to java
1.4. Java is currently in 1.4.1_02, so it should be pretty solid. I
don't really understand the last error that you're getting, but hopefully
an upgrade to 1.4 will take care of the problem.
  Chris
On Wed, 30 Apr 2003, Paul Hasenohr wrote:
init:
all:
    [javac] ^
    [javac] ^
Logger.getLogger("org.vfny.geoserver.config");
    [javac] ^
    [javac]
resolve symbol
    [javac] ^
    [javac] ^
    [javac] ^
    [javac] ^
    [javac] 7 errors
BUILD FAILED
output for details.
Thanks
Paul
Thanks, everything seems to work
Paul
-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: mercredi 30 avril 2003 15:13
To: Paul Hasenohr
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] error in compiling geoserver.war
  Chris
ant
init:
all:
    [javac]
    [javac] ^
    [javac]
    [javac] ^
    [javac]
    [javac] ^
    [javac]
resolve symbol
    [javac] ^
    [javac]
    [javac] ^
    [javac]
    [javac] ^
    [javac]
    [javac] ^
    [javac] 7 errors
BUILD FAILED
Thanks
Paul
This sf.net email is sponsored by:ThinkGeek
Welcome to geek heaven.
http://thinkgeek.com/sf _______________________________________________
Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net
