Hello,
I'm getting the bellow exception when executing a GetMap request like
the following on both 2.1.x and trunk:
<http://localhost:8080/geoserver/wms?LAYERS=nurc%3AArc_Sample&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=1335507.7609878,-1574602.7798854,1336119.2572141,-1573991.2836591&WIDTH=256&HEIGHT=256>
Data directory is the release one, layer nurc:Arc_Sample.
I'm on linux, java is
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) 64-Bit Server VM (build 20.1-b02, mixed mode)
It happens with both native JAI/ImageIO installed and not.
So before filing a jira I just wanted to ask whether this is something
knew, it happens only to me, or it's actually worth a bug report?
Gabriel
02 Dec 19:04:17 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on
the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:333)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:249)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:124)
at org.geoserver.wms.GetMap.run(GetMap.java:377)
Caused by: java.lang.IllegalArgumentException: Dimensions (width=46604
height=48031) are too large
at java.awt.image.SampleModel.<init>(SampleModel.java:112)
at java.awt.image.ComponentSampleModel.<init>(ComponentSampleModel.java:128)
at java.awt.image.PixelInterleavedSampleModel.<init>(PixelInterleavedSampleModel.java:69)
at java.awt.image.ComponentColorModel.createCompatibleSampleModel(ComponentColorModel.java:2841)
at org.geotools.image.ImageWorker.forceComponentColorModel(ImageWorker.java:1275)
at org.geotools.image.ImageWorker.forceComponentColorModel(ImageWorker.java:1312)
at org.geotools.image.ImageWorker.forceComponentColorModel(ImageWorker.java:1153)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:999)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:331)
Gabriel Roldan
OpenGeo - http://opengeo.org
