Embedded error: Error creating bean with name ‘config’ defined in URL [jar:file:/C:/Documents%20and%20Settings/gerhardg/
.m2/repository/org/geoserver/main/1.4.0-M0/main-1.4.0-M0.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NullPointerException: null
I think I know what the problem is. It has to do with the config deployment maven plugin. I changed the structure of the maven plugins to be similar to geotools, everything under a subdirectory maven, i think i screwed something up in the process.
A quick solution to get you running is to go to maven/config and do a maven install from there. Then you should be able to run from the web module. I will work on a better fix.
-Justin
Gerhard Goosen wrote:
I have successfully build the geoserver 1.4.x but I am getting a Error when I use:
*Embedded error: Error creating bean with name 'config' defined in URL [jar:file:/C:/Documents%20and%20Settings/gerhardg/*
*.m2/repository/org/geoserver/main/1.4.0-M0/main-1.4.0-M0.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NullPointerException: null*
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GG is reviewing the docs that I am writing so that is how he found the error. Should we include the quick solution in the docs..? Or else we can ignore this problem for now.
Kind Regards
Clint Lewis
-Justin
May as well wait till you fix it ... Gerhard is working through QA on the documentation. Quick fix not needed.
Jody
Nope, it should never come up, its an error in the build system. I just committed the fix.
-Justin
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
-Justin
