[Geoserver-devel] Error when cascading a WMS web service with GeoServer
Hey sure, here the whole first message error :
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Error rendering coverage on the fast path
java.io.IOException: GetMap failed: http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?SERVICE=WMS&LAYERS=GEOGRAPHICALGRIDSYSTEMS.MAPS&CRS=EPSG:3857&FORMAT=image%2Fpng&HEIGHT=388&TRANSPARENT=FALSE&BGCOLOR=0xFFFFFF&REQUEST=GetMap&BBOX=-4.0075016E7,-2.55379835625E7,4.0075016E7,3.52007125625E7&WIDTH=512&STYLES=&VERSION=1.3.0
2013/11/22 Rahkonen Jukka [via OSGeo.org] <[hidden email]>
it is impossible to answer with that information. Show us the failed GetMap () so we can see what it is missing. You can edit it to have http://foo.com/foowms? , the real address is not so important.
-Jukka Rahkonen-
SecularKid wrote:
I tried to cascade a remote WMS service using GeoServer. After configuration,
GeoServer allows me to publish data from this remote service.
But I try to display it, in the layer preview, the tile is broken.
I copy and paste the URL of this broken tile, and I got this error message :
java.io.IOException: GetMap failed () GetMap failed ()
This time, when I copy and paste the () from the error
message, I got this :
Resource parameter not found
What should I do to make it work ? If I request it directly from OpenLayers,
everything is displaying fine.
Thanks by advance.
Vincent
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-
when-cascading-a-WMS-web-service-with-GeoServer-tp5090615.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Shape the Mobile Experience: Free Subscription Software experts and
developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
[hidden email]
Software experts and developers: Be at the forefront of tech innovation.
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Error-when-cascading-a-WMS-web-service-with-GeoServer-tp5090615p5090618.html
To unsubscribe from Error when cascading a WMS web service with GeoServer, click here.
NAML
This server and site is not configured in the most usual way. The GetCapabilities is captured from http:// address and it is also advertised to be the GetMap address in the GetCapabilities document. You can see this by sending:
http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
However, the site is using a temporary redirecting which says that in reality the GetMap must be sent to a https:// secured adress. If this new address is used some clients deny it because of an untrusted sertificate.
Now I fear that we will need Andrea or some other real developer to tell if Geoserver when it cascades WMS can follow http redirections (http 302 Moved Temporarily). I paste here what I got on console when making a trial with wget. Sorry about line breaks and Finnish messages.
C:\ohjelmat\GnuWin32\bin>wget "http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/g
SYSTEM_WGETRC = c:/progra~1/wget/etc/wgetrc
syswgetrc = C:\ohjelmat\GnuWin32/etc/wgetrc
--2013-11-22 21:04:57-- http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoport
=1.3.0
Selvitetään osoitetta gpp3-wxs.ign.fr... 160.92.169.129
Yhdistetään palvelimeen gpp3-wxs.ign.fr|160.92.169.129|:80... yhdistetty.
HTTP-pyyntö lähetetty, odotetaan vastausta... 302 Moved Temporarily
Sijainti: https://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?SERV
5379835625E7,4.0075016E7,3.52007125625E7&WIDTH=512&STYLES=&VERSION=1.3.0 [seurat
aan]
--2013-11-22 21:05:01-- https://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geopor
N=1.3.0
Yhdistetään palvelimeen gpp3-wxs.ign.fr|160.92.169.129|:443... yhdistetty.
VIRHE: ei voida todentaa kohteen gpp3-wxs.ign.fr varmennetta, myöntäjä: "/C=US/O
=Entrust, Inc./OU=www.entrust.net/rpa is incorporated by reference/OU=(c) 2009 E
ntrust, Inc./CN=Entrust Certification Authority - L1C":
  Itse allekirjoitettu varmenne kohdattu.
Ottaaksesi yhteyden kohteeseen gpp3-wxs.ign.fr:n turvattomasti, käytä "--no-chec
k-certificate"-valitsinta.
SSL-yhteyden muodostaminen ei onnistunut.
-Jukka Rahkonen-
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://129.182.247.82:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt; <ServiceExceptionReport version="1.1.1" > <ServiceException>
java.io.IOException: GetMap failed: http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?SERVICE=WMS&amp;LAYERS=GEOGRAPHICALGRIDSYSTEMS.MAPS&amp;CRS=EPSG:3857&amp;FORMAT=image%2Fpng&amp;HEIGHT=388&amp;TRANSPARENT=FALSE&amp;BGCOLOR=0xFFFFFF&amp;REQUEST=GetMap&amp;BBOX=-4.0075016E7,-2.55379835625E7,4.0075016E7,3.52007125625E7&amp;WIDTH=512&amp;STYLES=&amp;VERSION=1.3.0
</ServiceException></ServiceExceptionReport>
2013/11/22 Rahkonen Jukka [via OSGeo.org] <[hidden email]<UrlBlockedError.aspx>>
it is impossible to answer with that information. Show us the failed GetMap (<URL of the request>) so we can see what it is missing. You can edit it to have http://foo.com/foowms? , the real address is not so important.
-Jukka Rahkonen-
java.io.IOException: GetMap failed (<URL of the request>) GetMap failed (<URL
of the request>)
This time, when I copy and paste the (<URL of the request>) from the error
<ExceptionReport>
<Exception exceptionCode="MissingParameter">Resource parameter not
found</Exception></ExceptionReport>
Thanks by advance.
Vincent
[hidden email]<http://user/SendEmail.jtp?type=node&node=5090618&i=0&gt;
[hidden email]<http://user/SendEmail.jtp?type=node&node=5090618&i=1&gt;
To unsubscribe from Error when cascading a WMS web service with GeoServer, click here<UrlBlockedError.aspx>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html!nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers!nabble%3Aemail.naml-instant_emails!nabble%3Aemail.naml-send_instant_email!nabble%3Aemail.naml&gt;
View this message in context: Re: Error when cascading a WMS web service with GeoServer<http://osgeo-org.1560.x6.nabble.com/Re-Error-when-cascading-a-WMS-web-service-with-GeoServer-tp5090622.html&gt;
Sent from the GeoServer - Dev mailing list archive<http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html&gt; at Nabble.com.
Thanks for investigation :slight_smile: !
So if I understand, the GetCapabilities is “cascading himself” the GetMap service to a https server.
I contacted a guy that could eventually support me (he is working at the IGN).
He told me that I could remove gpp3 from the URL (it wont’ change anything I think), and that it is normal that I get the layer to publish because are not protected as they are public data. But maybe that could give a hint on the fact the error is coming from the https request, as you suggested.
I’ll ask him on this fact.
I can’t really develop something inside GeoServer or so to make it work because I can’t develop in Java :(.
Thanks anyway, I’ll keep searching and if I find a solution I’ll keep the community warned !
2013/11/22 Rahkonen Jukka <jukka.rahkonen@anonymised.com>
C:\ohjelmat\GnuWin32\bin>wget “http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/g
–2013-11-22 21:04:57-- http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoport
=1.3.0
Selvitetään osoitetta gpp3-wxs.ign.fr… 160.92.169.129
Yhdistetään palvelimeen gpp3-wxs.ign.fr|160.92.169.129|:80… yhdistetty.
HTTP-pyyntö lähetetty, odotetaan vastausta… 302 Moved Temporarily
aan]
–2013-11-22 21:05:01-- https://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geopor
N=1.3.0
Yhdistetään palvelimeen gpp3-wxs.ign.fr|160.92.169.129|:443… yhdistetty.
VIRHE: ei voida todentaa kohteen gpp3-wxs.ign.fr varmennetta, myöntäjä: “/C=US/O
ntrust, Inc./CN=Entrust Certification Authority - L1C”:
Ottaaksesi yhteyden kohteeseen gpp3-wxs.ign.fr:n turvattomasti, käytä “–no-chec
k-certificate”-valitsinta.
-Jukka Rahkonen-
-Jukka Rahkonen-
Thanks by advance.
Vincent
[hidden email]<http://user/SendEmail.jtp?type=node&node=5090618&i=0>
[hidden email]<http://user/SendEmail.jtp?type=node&node=5090618&i=1>
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: Error when cascading a WMS web service with GeoServer<http://osgeo-org.1560.x6.nabble.com/Re-Error-when-cascading-a-WMS-web-service-with-GeoServer-tp5090622.html>
Sent from the GeoServer - Dev mailing list archive<http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html> at Nabble.com.
On Fri, Nov 22, 2013 at 8:21 PM, Rahkonen Jukka
<jukka.rahkonen@anonymised.com>wrote:
Thanks Jukka, I've recorded your findings in the ticket Vincent opened:
https://jira.codehaus.org/browse/GEOS-6183
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Some more information: If I read GetCapabilities as
https://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
the GetMap URL is advertised also to use https protocol
"https://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?&quot;
If that URL is used for GetMaps there will not happen 302 redirection on the IGN side.
Vincent, please try what happens if you create a new WMS connection by using the above https URL as the "Capabilities URL".
-Jukka-
andrea aime wrote:
On Fri, Nov 22, 2013 at 8:21 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com<mailto:jukka.rahkonen@anonymised.com>> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
I'll also need to work next week so I tried it right now. It works with https URL.
-Jukka-
Vincent Dechandon wrote:
Thanks dude, this is the week-end so I won't be able to test it until Monday. I'll keep you updated !
Have a nice week-end :slight_smile:
Le 22 nov. 2013 21:48, "Rahkonen Jukka" <jukka.rahkonen@anonymised.com<mailto:jukka.rahkonen@anonymised.com>> a écrit :
-Jukka-
andrea aime wrote:
On Fri, Nov 22, 2013 at 8:21 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com<mailto:jukka.rahkonen@anonymised.com><mailto:jukka.rahkonen@anonymised.com>> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax: +39 0584 1660272<tel:%2B39%200584%201660272>
mob: +39 339 8844549<tel:%2B39%20%20339%208844549>
