Request looks good at the first sight. However, I am not sure if Geoserver can cascade WMS 1.3.0 nowadays. Documentation does not tell that http://docs.geoserver.org/stable/en/user/data/cascaded/wms.html
I wonder also if GEOGRAPHICALGRIDSYSTEMS.MAPS is a valid WMS layer name. Are dots in names really OK?
But the error seems to come from the remote service. Perhaps authentication fails.
-Jukka Rahkonen-
SecularKid wrote:
Hey sure, here the whole first message error :
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Error rendering coverage on the fast path
java.io.IOException: GetMap failed: http://gpp3-wxs.ign.fr/4hnoob7ikk8zb8rzj113echo/geoportail/r/wms?SERVICE=WMS&LAYERS=GEOGRAPHICALGRIDSYSTEMS.MAPS&CRS=EPSG:3857&FORMAT=image%2Fpng&HEIGHT=388&TRANSPARENT=FALSE&BGCOLOR=0xFFFFFF&REQUEST=GetMap&BBOX=-4.0075016E7,-2.55379835625E7,4.0075016E7,3.52007125625E7&WIDTH=512&STYLES=&VERSION=1.3.0
2013/11/22 Rahkonen Jukka [via OSGeo.org] <[hidden email]>
it is impossible to answer with that information. Show us the failed GetMap () so we can see what it is missing. You can edit it to have http://foo.com/foowms? , the real address is not so important.
-Jukka Rahkonen-
SecularKid wrote:
I tried to cascade a remote WMS service using GeoServer. After configuration,
GeoServer allows me to publish data from this remote service.
But I try to display it, in the layer preview, the tile is broken.
I copy and paste the URL of this broken tile, and I got this error message :Error rendering coverage on the fast path
java.io.IOException: GetMap failed () GetMap failed ()This time, when I copy and paste the () from the error
Resource parameter not found
message, I got this :What should I do to make it work ? If I request it directly from OpenLayers,
everything is displaying fine.
Thanks by advance.Vincent
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-
when-cascading-a-WMS-web-service-with-GeoServer-tp5090615.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Shape the Mobile Experience: Free Subscription Software experts and
developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
[hidden email]
Software experts and developers: Be at the forefront of tech innovation.
[hidden email]
If you reply to this email, your message will be added to the discussion below:
To unsubscribe from Error when cascading a WMS web service with GeoServer, click here.
NAML
View this message in context: Re: Error when cascading a WMS web service with GeoServer
