I've downloaded the binary version of 2.0 and haven't changed any of my data files. When I attempt to disable a raster store, I get this error:
No grid format found capable of connection to the provided URL
Disabling works fine with vector stores.
Is this something I did? Or a bug? Should I put it in JIRA?
Alyssa.
Hi
I have a postgis table loaded in to geoserver, this table has two Geometry data columns, which will geoserver use when it display the table ?
Hey Alyssa,
Definitely sounds like a bug, so yeah, please file a jira, feel free to make it a high priority since it would appear to be a regression.
-Justin
alyssa wright wrote:
Alyssa.
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Dave,
Well if you leave it to chance it will most likely use the first one it finds iterating through attributes. But when you create a symbolizer in an SLD you can specify explicitly which geometry property to use with the "<Geometry>" element.
-Justin
Dave Potts wrote:
Hi
Justin Deoliveira
Hi Justin.
Thanks for the tip, I will try it tonight.
I was going to declare a "view" on the table and ensure that the view only
help one geometry column, Not a nice solution, but one that would work.
Dave.
Hi Dave,
-Justin
Dave Potts wrote:
Hi
table ?
Justin Deoliveira
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
