Hello,
I am using GeoServer 1.6 RC1 with Tomcat 5.5. I want to use the ImageMosaic
plugin starting with the demo data that comes with GeoServer. During my
initial work I tried to display nurc:mosaic within OpenLayers using the
GeoServer Map Preview. When I click on OpenLayers, I get a window popping
up asking me if I want to open/download a 'vnd.ogc.se_xml' file. I click
'yes' and when looking at the contents I see:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
java.lang.NullPointerException
</ServiceException></ServiceExceptionReport>
In the geoserver.log, I see:
2007-11-21 08:40:23,223 DEBUG [org.vfny.geoserver.global] - getting coverage
nurc:mosaic
2007-11-21 08:40:23,223 WARN [org.geoserver.ows] -
at org.vfny.geoserver.global.Data.getCoverageInfo(Data.java:1311)
at
org.geoserver.wms.kvp.GetMapKvpRequestReader.findCoverageLayer(GetMapKvpRequestReader.java:1117)
at
org.geoserver.wms.kvp.GetMapKvpRequestReader.buildMapLayerInfo(GetMapKvpRequestReader.java:1078)
at
org.geoserver.wms.kvp.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1011)
at
org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:176)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:995)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:371)
Any ideas of what I am doing wrong?
Thanks, Bob
View this message in context: http://www.nabble.com/Error-with-ImageMosaic-tf4850410.html#a13878067
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Bob Nutsch ha scritto:
Hello,
nurc:mosaic
2007-11-21 08:40:23,223 WARN [org.geoserver.ows] - java.lang.NullPointerException
at
at
at
at
Hmm... that can happen only if there is no default namespace anymore in the geoserver configuration... sigh, the namespace UI is missing quite a bit of checks... can you try configuring back a default namespace?
You rock Andrea! That was it! Once I set a default namespace all is well.
Thank you very much!
Bob
Hello,
ImageMosaic
popping
coverage
nurc:mosaic
at
at
at
at
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/Error-with-ImageMosaic-tf4850410.html#a13878719
