I am getting the following error when I try to do a getCapabilitties on WMS with the current trunk code
09 Sep 15:35:01 INFO [responses.helpers] - Supported JAIMapResponse’s MIME Types
: [image/jpeg]
09 Sep 15:35:03 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Translator error
at org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSC
apabilitiesResponse.java:152)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapte
r.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:699)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:21
6)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
AbstractController.java:153)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.ha
ndle(SimpleControllerHandlerAdapter.java:48)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(Dispatch
erServlet.java:875)
at org.springframework.web.servlet.DispatcherServlet.doService(Dispatche
rServlet.java:809)
at org.springframework.web.servlet.FrameworkServlet.processRequest(Frame
workServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServl
et.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl
icationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF
ilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCha
racterEncodingFilter.java:108)
icationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(F
ilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(Filt
erSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Fi
lterSecurityInterceptor.java:72)
ilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTra
nslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFil
ter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicPr
ocessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilte
r(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.jav
a:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.j
ava:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.
java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV
alve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV
alve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j
ava:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j
ava:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal
ve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav
a:286)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcesso
r.java:857)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.pr
ocess(Http11AprProtocol.java:565)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:15
09)
at java.lang.Thread.run(Thread.java:619)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.
java:133)
java:108)
apabilitiesResponse.java:150)
… 51 more
Caused by: org.vfny.geoserver.wms.WmsException: Error occurred trying to write o
ut metadata for layer: test
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$Capabilit
iesTranslator.handleLayerTree(WMSCapsTransformer.java:654)
iesTranslator.handleLayers(WMSCapsTransformer.java:533)
iesTranslator.handleCapability(WMSCapsTransformer.java:342)
iesTranslator.encode(WMSCapsTransformer.java:224)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(Tra
nsformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(Transf
ormerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.j
ava:296)
java:129)
… 53 more
Caused by: java.lang.RuntimeException: Unexpected error obtaining bounding box f
or layer test
iesTranslator.handleLayer(WMSCapsTransformer.java:717)
iesTranslator.handleLayerTree(WMSCapsTransformer.java:651)
… 60 more
Caused by: java.lang.NullPointerException: Unable to transform referenced envelo
pe, crs has not yet been provided.
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnve
lope.java:613)
lope.java:579)
at org.geoserver.catalog.impl.ResourceInfoImpl.boundingBox(ResourceInfoI
mpl.java:201)
at sun.reflect.GeneratedMethodAccessor106.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy
.java:113)
at $Proxy11.boundingBox(Unknown Source)
iesTranslator.handleLayer(WMSCapsTransformer.java:715)
… 61 more
Thanks and Warm Regards
Debasish Sahu
