[Geoserver-devel] Error
I got this from the "Server Configuration" page.
(http://localhost:8080/geoserver/config/server.do)
David
[ServletException in:/WEB-INF/pages/GeoServerConfiguration.jsp]
/home/dzwiers/geoserver/server/geoserver/WEB-INF/work/WEB-INF/pages/GeoServerConfiguration_jsp.java (Permission denied)' java.io.FileNotFoundException: /home/dzwiers/geoserver/server/geoserver/WEB-INF/work/WEB-INF/pages/GeoServerConfiguration_jsp.java (Permission denied) at java.io.FileOutputStream.open(Native Method) at java.io.FileOutputStream.(FileOutputStream.java:179) at java.io.FileOutputStream.(FileOutputStream.java:70) at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:216) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:369) at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:473) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:190) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:295) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:241) at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358) at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:294) at org.mortbay.jetty.servlet.Dispatcher.dispatch(Dispatcher.java:222) at org.mortbay.jetty.servlet.Dispatcher.include(Dispatcher.java:127) at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:822) at org.apache.jasper.runtime.PageContextImpl.include(PageContextImpl.java:398) at org.apache.struts.tiles.TilesUtilImpl.doInclude(TilesUtilImpl.java:137) at org.apache.struts.tiles.TilesUtil.doInclude(TilesUtil.java:177) at org.apache.struts.taglib.tiles.InsertTag.doInclude(InsertTag.java:756) at org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag(InsertTag.java:881) at org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag.java:473) at org.apache.jsp.mainLayout_jsp._jspx_meth_tiles_insert_6(mainLayout_jsp.java:1283) at org.apache.jsp.mainLayout_jsp._jspService(mainLayout_jsp.java:485) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:137) at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:210) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:295) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:241) at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358) at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:294) at org.mortbay.jetty.servlet.Dispatcher.dispatch(Dispatcher.java:222) at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:135) at org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1069) at org.apache.struts.tiles.TilesRequestProcessor.doForward(TilesRequestProcessor.java:274) at org.apache.struts.tiles.TilesRequestProcessor.processTilesDefinition(TilesRequestProcessor.java:254) at org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:309) at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:279) at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482) at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:507) at javax.servlet.http.HttpServlet.service(HttpServlet.java:740) at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358) at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:294) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567) at org.mortbay.http.HttpContext.handle(HttpContext.java:1807) at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525) at org.mortbay.http.HttpContext.handle(HttpContext.java:1757) at org.mortbay.http.HttpServer.service(HttpServer.java:879) at org.mortbay.http.HttpConnection.service(HttpConnection.java:790) at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961) at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807) at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197) at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276) at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
hi david,
it seems that geoserver is not allowed to access the file
"/home/dzwiers/geoserver/server/geoserver/WEB-INF/work/WEB-INF/pages/GeoServerConfiguration_jsp.java"
so first, check the rights of each directory of the path and the file "GeoServerConfiguration_jsp.java" and make sure all directories have at least "r" and "x" permission for all users...
another thing is maybe in your servlet container, you have to specify permissions for geoserver...
i don't know which servlet container you are using but the interesting config file must be a "dot policy" extension (like catalina.policy or server.policy)....
and the lines you have to add at the end of this file look like :
grant codeBase "file:pathToYourAppli/geoserver/-"{
    permission java.io.FilePermission "/home/dzwiers/geoserver/server/geoserver/WEB-INF/work/WEB-INF/pages/", "read,write,delete";
i hope this can be helpful
regards.
antoine.
David
e
t
This SF.Net email is sponsored by: InterSystems CACHE
FREE OODBMS DOWNLOAD - A multidimensional database that combines
robust object and relational technologies, making it a perfect match
for Java, C++,COM, XML, ODBC and JDBC. www.intersystems.com/match8
Geoserver-devel mailing list
Thanks Antoine, I must have been root when unziping the archive (some
time ago).
David
On Wed, 2004-11-17 at 13:11, Antoine Hnawia wrote:
hi david,
server.policy)....
regards.
antoine.
>David
>e
>t
>_______________________________________________
>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
