[Geoserver-devel] Errors Building Geoserver in Eclipse
I'm building Geoserver from source, and I've encountered several errors. (For
reference, I'm following this guide:
http://docs.geoserver.org/stable/en/developer/quickstart/index.html#check-out-
source-code)
If I build from trunk, the command-line build succeeds (mvn clean install), but
after opening the project in Eclipse, there are a number of build errors, mostly
following the format:
"Project is missing required library: '[...]/m2/repository/org/geotools/gt-
api/2.6-SNAPSHOT/gt-api-2.6-SNAPSHOT.jar'"
Any ideas as to what's wrong here?
On another note, if I build from the 1.7.x branch, I get:
[ERROR] BUILD ERROR
[INFO] Failed to execute: Executing Ant script: /config.build.xml [config]:
Failed to execute.
Unable to locate configuration: /home/tilden/Downloads/svn/geoserver-
1.7.2/src/web/minimal
I noticed that someone else had posted the same error previously, but it seemed
that he was never able to get it working. Any ideas for getting this working?
On Wed, Nov 10, 2010 at 12:25 PM, Dan Tilden <gerbilsrule@anonymised.com5…> wrote:
I’m building Geoserver from source, and I’ve encountered several errors. (For
reference, I’m following this guide:
source-code)
“Project is missing required library: ‘[…]/m2/repository/org/geotools/gt-
api/2.6-SNAPSHOT/gt-api-2.6-SNAPSHOT.jar’”
Any ideas as to what’s wrong here?
The most likely cause is that you have not added the maven package cache as a classpath variable in eclipse. Instructions on doing so are included in the eclipse setup section of the developer documentation ( http://docs.geoserver.org/stable/en/developer/quickstart/index.html#import-modules-into-eclipse); are you following those?
[ERROR] BUILD ERROR
Failed to execute.
src/web/minimal/ is not actually checked into SVN exactly; it is fetched automatically via SVN externals. If you are not using SVN to retrieve the sources, then you will need to either copy the minimal configuration from data/ manually, or set the configDirectory and configId properties in your maven command (-DconfigDirectory=…).
David Winslow
OpenGeo - http://opengeo.org/
For 1.7.x see -DconfigDirectory and -DconfigId at <http://geoserver.org/display/GEOSDOC/Maven+Build+Reference&gt;
for 2.0.x and trunk... sure you ran mvn eclipse:eclipse on the top project directory (src)?
If yes please provide the full steps that you followed.
when importing the src directory into eclipse you should get a bunch of projects(platform, main, wms, wfs, etc)
source-code)
[ERROR] BUILD ERROR
Failed to execute.
The Next 800 Companies to Lead America's Growth: New Video Whitepaper
David G. Thomson, author of the best-selling book "Blueprint to a
Billion" shares his insights and actions to help propel your
business during the next growth cycle. Listen Now!
http://p.sf.net/sfu/SAP-dev2dev
Geoserver-devel mailing list
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
