[Geoserver-devel] Expired Certificate on Build Server
the build server tls certificate expired on September the 2nd, who can fix it?
https://build.geoserver.org/
Thank you
Lorenzo Pini
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Lorenzo Pini
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I reached out to Tome, the certificate should be fixed now.
Jody Garnett
