[Geoserver-devel] Exposing OL2 and OL3 previews at the same time
I would like to propose we bring back the OL2 preview as an alternative output format “application/openlayers2”.
The reason is quite simple, I’m tired of pulling hairs with the current canvas based preview.
I just spend some days debugging issues that were happening mostly when doing requests in tiled mode,
and hunting down the right request in the network logs has been quite a drag of time.
Yes, there is a system variable to bring back the OL2 preview, but it’s not the default, cannot be easily
activated on a production system.
Also, at least from a didactic perspective, it’s nice to pull up OL2 and tell the students to just right click on the
map/the tiles and see that it’s really just a WMS call, rather than pulling up the dev tools and also explain
them the network view in the process.
Of course I’m not proposing to simply go back to OL2, but in some ways the OL3 preview is not
a full replacement for the old OL2, so imho best to have them both available at the same time
by just changing a request parameter, keeping OL2 as a possible option while OL3+ remains
the default for previews.
Objections? :slight_smile:
PS: another very annoying thing is that the OL3 preview just shows nothing when
a request fails, instead of a “broken image” like in OL2, but I guess for this there are solutions,
like using “error in image” for exceptions or something like that, sounds more like a bug in need
of fixing instead of an architectural problem.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Yes, please - I was struggling with this the other day.
Ian
On 5 October 2017 at 14:31, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ian Turton
I wonder how practical it would be to replicate this functionality in OL3? Maybe something that could plug into a tile layer to generate a vector overlay where each request is represented as a feature. More work than just using OL2 but it might be worth suggesting to the OL developers.
Ian
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Geoserver-devel@anonymised.comsourceforge.net
Ian Turton
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
That sounds quite complicated, not sure OL devs are going to be interested,
but if you want to try, go ahead.
Gut feeling, they will tell you to implement it custom in the GeoServer OL
preview.
In the meantime I've proposed a 30 minutes change:
https://github.com/geoserver/geoserver/pull/2575
Ing. Andrea Aime
@geowolf
Technical Lead
