You replied to me and not the list, we should keep conversation with the group. The PR was accepted this morning so you should be able to access it from the nightly build now.
The documentation should be available now on the website but I do not see it yet
I went to the nightly builds @ [https://build.geoserver.org/geoserver/2.19.x/](https://build.geoserver.org/geoserver/2.19.x/) and downloaded and unpacked [geoserver-2.19.x-latest-bin.zip](https://build.geoserver.org/geoserver/2.19.x/geoserver-2.19.x-latest-bin.zip)
I didn’t see any cite stuff. Am I in the right place?
Also what website will the documentation be available on?
Patrick Jones
From: Jody Garnett <jody.garnett@…403…> Sent: Tuesday, July 20, 2021 2:21 PM To: Patrick L Jones <plj@…6917…>; GeoServer geoserver-devel@lists.sourceforge.net Subject: Re: [EXT] Re: [Geoserver-users] wfs cite tests
THanks Patgrick
Jody Garnett
On Tue, 20 Jul 2021 at 06:42, Patrick L Jones <plj@…6917…> wrote:
Thanks for the quick reply!!
Unfortunately I’m not an expert in Git. From the site https://github.com/geoserver/geoserver/pull/4907 is there a way for me to download the current docker (or build it) so I can run the tests?
Those cite tests from jdeolive are from 2012 and we are in the process of being replaced.
And one of the last things to do for the replacement is to check that the replacement (which uses Docker) can be run and understood by normal developers.
I’d suggest moderating your expectations on what will happen too. The tests are buggy, and geoserver hasn’t been getting regular checks, so either or both may have issues.
