[Geoserver-devel] Extend Windows Installer features
I’s looking at some improvements for the Windows installer of GeoServer.
For now I’m thinking about the following features:
  • Better upgrade path of a single GeoServer installation
    • Remember ‘Service’ and ‘Port’ settings – ENHANCEMENT
    • Uninstall previous version, before installing the new version – BEHAVIOR CHANGE
    • Non-versioned Windows Service Name (for easier use in script/batch files) – BEHAVIOR CHANGE
  • Named GeoServer installations – ENHANCEMENT
    • This would allow you to install multiple instances of GeoServer on the same machine, with each having its own upgrade path:
      • Will required multiple registry keys
      • Instances selection/specification
      • Multiple service names
      • IP-Port specification per instance (available)
    • When starting the installation, initially the ‘single instance’ setup will be used (the way the setup is working now).
But before I start with this, I was wondering if there are objections to these features and/or changes.
And regarding the instances, if there is some actual need!
Ronald Hoek
Application Developer
ComponentAgroB.V.
Oud-Beijerland - The Netherlands
Website: http://www.componentagro.nl
KvK: H24264020
