[Geoserver-devel] Extend Windows Installer features
Installer should also have an option to install Geoserver as Windows service with 64 bit Java.
-Jukka Rahkonen-
Lähettäjä: Ronald Hoek - ComponentAgro B.V. [mailto:ronald.hoek@anonymised.com]
Lähetetty: 22. toukokuuta 2018 10:36
Vastaanottaja: geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] Extend Windows Installer features
I’s looking at some improvements for the Windows installer of GeoServer.
For now I’m thinking about the following features:
  • Better upgrade path of a single GeoServer installation
o Remember ‘Service’ and ‘Port’ settings – ENHANCEMENT
o Uninstall previous version, before installing the new version – BEHAVIOR CHANGE
o Non-versioned Windows Service Name (for easier use in script/batch files) – BEHAVIOR CHANGE
  • Named GeoServer installations – ENHANCEMENT
o This would allow you to install multiple instances of GeoServer on the same machine, with each having its own upgrade path:
§ Will required multiple registry keys
§ Instances selection/specification
§ Multiple service names
§ IP-Port specification per instance (available)
o When starting the installation, initially the ‘single instance’ setup will be used (the way the setup is working now).
But before I start with this, I was wondering if there are objections to these features and/or changes.
And regarding the instances, if there is some actual need!
Ronald Hoek
Application Developer
ComponentAgroB.V.
Oud-Beijerland - The Netherlands
Website: http://www.componentagro.nl
KvK: H24264020
Hello Jukka,
At this point only 32-bit is supported on Windows, as there’s only a 32-bit service wrapper (zie ‘wrapper.exe’).
I don’t have any experience with the service wrapper itself (only with the installer).
So if you can help with acquiring a 64-bit service wrapper, I could then look into including this into the setup.
Ronald Hoek
ComponentAgroB.V.
KvK: H24264020
Van: Rahkonen Jukka (MML) jukka.rahkonen@anonymised.com
Verzonden: dinsdag 22 mei 2018 9:48
Aan: Ronald Hoek ronald.hoek@anonymised.com; geoserver-devel@anonymised.comts.sourceforge.net
Onderwerp: Re: Extend Windows Installer features
-Jukka Rahkonen-
