[Geoserver-devel] Extend Windows Installer features
The community edition of the wrapper is not available for 64 bit Windows https://wrapper.tanukisoftware.com/doc/english/download.jsp. However, I do not really know if there is continuous interaction between the wrapper and JVM once the service is installed so that they must be of the same architecture. Perhaps it if possible to use 32 bit wrapper and still run the service with 64 bit JVM. But if I remember right the user must select 32 bit JVM for running the Geoserver installer and switching to 64 bit JVM would require some tweaking if it is possible. I try to find some time for a few tests.
This comes actual with Java 9 and above because they are not available as 32 bit versions.
-Jukka Rahkonen-
Lähettäjä: Ronald Hoek - ComponentAgro B.V. [mailto:ronald.hoek@anonymised.com…5024…]
Lähetetty: 22. toukokuuta 2018 11:10
Vastaanottaja: Rahkonen Jukka (MML) jukka.rahkonen@anonymised.com; geoserver-devel@lists.sourceforge.net
Aihe: RE: Extend Windows Installer features
Hello Jukka,
At this point only 32-bit is supported on Windows, as there’s only a 32-bit service wrapper (zie ‘wrapper.exe’).
I don’t have any experience with the service wrapper itself (only with the installer).
So if you can help with acquiring a 64-bit service wrapper, I could then look into including this into the setup.
Ronald Hoek
Application Developer
ComponentAgroB.V.
Oud-Beijerland - The Netherlands
Website: http://www.componentagro.nl
KvK: H24264020
Van: Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com>
Verzonden: dinsdag 22 mei 2018 9:48
Aan: Ronald Hoek <ronald.hoek@anonymised.com>; geoserver-devel@anonymised.comsts.sourceforge.net
Onderwerp: Re: Extend Windows Installer features
Installer should also have an option to install Geoserver as Windows service with 64 bit Java.
-Jukka Rahkonen-
Hi Jukka,
I’m not seeing any limits for the 64-bit version (in comparison to the 32-bit version).
https://wrapper.tanukisoftware.com/doc/english/product-features.html
So maybe it’s possible to create a 64-bit setup (not sure howto at this point :wink:) and add the 64-bit wrapper to it instead of the 32-bit…
Ronald Hoek
ComponentAgroB.V.
KvK: H24264020
Van: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>
Verzonden: dinsdag 22 mei 2018 10:32
Aan: Ronald Hoek <ronald.hoek@…5024…>; geoserver-devel@lists.sourceforge.net
-Jukka Rahkonen-
Lähettäjä: Ronald Hoek - ComponentAgro B.V. [mailto:ronald.hoek@…5024…]
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>; geoserver-devel@lists.sourceforge.net
Hello Jukka,
Ronald Hoek
ComponentAgroB.V.
KvK: H24264020
-Jukka Rahkonen-
On Tue, May 22, 2018 at 10:40 AM, Ronald Hoek - ComponentAgro B.V. <
ronald.hoek@anonymised.com> wrote:
Hi Jukka,
32-bit version).
Check the download page though:
"*1: 64-bit Windows versions of the Java Service Wrapper are not currently
being made available in the Community Edition."
Looks like something else needs to be used. Wondering what Tomcat is using,
for example.
Also check this out, might be helpful:
https://www.eclipse.org/jetty/documentation/9.4.x/startup-windows-service.html
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
