On Mon, Jan 15, 2018 at 11:13 AM, Watermeyer, Andreas <
Andreas.Watermeyer@anonymised.com> wrote:
Hello list,
we would like to use the control flow extension, but we need to configure
it per layer, which is currently not supported. We will implement something
for our project and we can offer to contribute the code.
1) Is there any interest in such a contribution?
Yes, that seems to be a useful addition, at least in principle. What's the
use case for doing it by layer? Typically I hear of users asking different
rules per user role instead (QoS classes).
Also, how do you handle requests with multiple layers? Most strict rule
applies?
I had a look at the code and I have some questions upfront, trying to
create a solution which is benefitial for the GeoServer project:
2) I have experience with WMS and WFS only. For WMS it is quite simple to
extract the layers from the URL. The GetMap implementation uses
a GetMapKvpRequestReader to extract the layers, which is part of gs-wms.
This also performs some validations but doesnt provide an API to extract
the layers only. I suggest not to use the GetMapKvpRequestReader but simply
check the HTTP request param "layers". Is this approach acceptable? Any
other recommendations?
3) To determine the affected WFS feature type is not so simple. The
information might be contained in an XML document, which is not parsed at
that point AFAICS. Duplicate parsing is not a solution. I currently dont
see a simple solution. In our project we need to restrict GetMap requests
only, so I will concentrate on a solution for WMS GetMap and leave the rest
open. Is this acceptable and still of worth for the community? I would log
some warnings if somebody configured a limit for a layer using
service-request-combination other than WMS-GetMap.
Doing your own parsing is indeed not an option. Check what the monitoring
module is doing, it's already extracting layer lists from the various
protocols, using a dedicated class fetching
the info post-parsing.
4) The configuration is currently as follows:
ows.<service>[.<request>[.<outputFormat>]]=<count>
4.1)
I suggest to extend it to
ows.<service>[.<request>[.<outputFormat>[.<layer>]]]=<count>
Actually the ordering is not quite as expected, it would be better to keep
it top-down (ows.<service>[.<request>[.<layer>[.<outputFormat>]]]), but
that would be a breaking change in the configuration.
Yeah, it's not exactly great. Thinking out loud, maybe it's time to switch
it to a XML format. Others might chime in with ideas too.
4.2)
As values for <outputFormat> I'd support an asterisk (*), matching all
formats.
4.3)
As value for layer I'd support an asterisk, too, for text matching, for
example to match a layers of a workspace (tiger:*)
Yep, the above is consistent with other usage in GeoServer (e.g., security)
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
