[Geoserver-devel] extension proposal
While waiting for maven builds and cite test runs I decided to whip up a proposal for the extension process that was discussed in IRC today.
http://geoserver.org/display/GEOS/GSIP+22+-+Extensions
Enjoy :).
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Sorry I missed the meeting today; the proposal seems fine, here are two ideas to consider:
- User Documentation: Installation / Configuration instructions to cut down on questions
- Are the extensions are freestanding or they are allowed to require each other? If possible it would be nice to keep these things independent; if they start depending on each other it may be a sign that the functionality belongs in core.
Jody
Justin Deoliveira wrote:
Enjoy :).
-Justin
Justin Deoliveira
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-devel mailing list
Sorry I missed the meeting too … I had a look at the proposal, not bad … but I thought the extension requirements were almost the same for community modules ready to be ported on trunk.
So … on my understanding the extension module will contain stable and approved GeoServer plugins that could be or not included in the release, is that right?
On Wed, Jun 11, 2008 at 5:01 AM, Jody Garnett <jgarnett@anonymised.com> wrote:
ideas to consider:
  • User Documentation: Installation / Configuration instructions to cut
    down on questions
  • Are the extensions are freestanding or they are allowed to require
Jody
http://geoserver.org/display/GEOS/GSIP+22±+Extensions
Enjoy :).
-Justin
Justin Deoliveira
It’s the best place to buy or sell services for
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
Hi Alessio,
Yup, they are pretty much the same. The major distinction is:
1. They are stable, maintained, and tested
2. They are explicitly released every time geoserver is released
Now a community module that is ready to be part of the core also fits those requirements, you are right. The difference is that the community module (when part of the core) is not optional, and does not get its own release artifact.
-Justin
Alessio Fabiani wrote:
Sorry I missed the meeting too ... I had a look at the proposal, not bad ... but I thought the extension requirements were almost the same for community modules ready to be ported on trunk.
So ... on my understanding the extension module will contain stable and approved GeoServer plugins that could be or not included in the release, is that right?
On Wed, Jun 11, 2008 at 5:01 AM, Jody Garnett <jgarnett@anonymised.com <mailto:jgarnett@anonymised.com>> wrote:
    ideas to consider:
    down on questions
    Jody
     > Hi all,
     > While waiting for maven builds and cite test runs I decided to
    whip up a
     > proposal for the extension process that was discussed in IRC today.
     > http://geoserver.org/display/GEOS/GSIP+22+-+Extensions
     > Enjoy :).
     > -Justin
     > Justin Deoliveira
     > The Open Planning Project
     > jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
     > Check out the new SourceForge.net Marketplace.
     > It's the best place to buy or sell services for
     > just about anything Open Source.
     > http://sourceforge.net/services/buy/index.php
     > Geoserver-devel mailing list
     > Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>
     > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
------------------------------------------------------- !DSPAM:4007,484f9a78250422143011171!
Justin Deoliveira
Thanks for the feedback Jody.
Good call. There is a bit of docs in the README for the extension, but that hardly cuts it. Adding a wiki page to the requirements.
Yeah... its not explicitly stated. But there are two paths for a community module to go when its "ready", that is to the core or to extension. Which path depends on the module and if it makes sense to have it an optional download.
As for dependencies... good question. Perhaps for now just manage it with maven + docs, and if it becomes a problem we can come up with something fancier.
Jody
Enjoy :).
-Justin
Justin Deoliveira
!DSPAM:4007,484f4039119401012714783!
Justin Deoliveira
Justin Deoliveira ha scritto:
Hum, the only thing that's surprising me a bit is the fact that extensions are not in the standard build, and that you have
to activate them with a profile, but I can go with that.
There is the following sentence that seem to be incomplete?
"The profile is added to release/pom.xml and ..."
Besides that, looks good
Hmmm... good point. I think you are right... since these things are stable they should be part of the build by default. If noone else objects I can change that.
Fixed :).
!DSPAM:4007,484ff2b8101111804284693!
Justin Deoliveira
Build early; build often - agreed this is a good idea. These are part of the standard build (ie geoserver project) ; but are not part of the standard release (ie geoserver product).
Jody
