On Wed, Aug 23, 2017 at 11:07 PM, Danilo da Silveira Figueira <danilomalzao@anonymised.com…21…> wrote:
Andrea,
I was thinking if wouldn’t be possible to do this using WCS with output format in PNG?
Att,
Danilo
2017-08-23 15:05 GMT-03:00 Danilo da Silveira Figueira <danilomalzao@anonymised.com>:
Ok, i will create the prototype :).
But where i can get information how to get the entire source code? Because for example the org.geotools.styling.ChannelSelection is part of a jar (gt-api-11), and even with the -DdownloadSources i cant edit the source code.
What i am doing wrong to not get all the source code dependencies?
2017-08-23 10:59 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Danilo,
that sounds great!
Just a word of warning, normally you should do the proposal first (maybe do a tiny prototype
to figure out where you want to make the changes, it’s up to you), and then the coding.
If you do the opposite, it’s fine too, but don’t complain if/when you get change request on your
proposal that will force you to rewrite part of the code
On Wed, Aug 23, 2017 at 3:51 PM, Danilo da Silveira Figueira <danilomalzao@anonymised.com> wrote:
Andrea,
Thanks for your reply, so i will propose this API change and code this by myself. After it i do the proposal for the developer team.
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
2017-08-23 5:16 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Danilo,
as far as I know there is no support for alpha channel in there.
You’ll have to make a code extension in GeoTools, which might not be simple since the current API,
derived from the SLD spec, goes like this:
- Set the RGB channels to be used
- @param red the red channel
- @param green the green channel
- @param blue the blue channel
void setRGBChannels(SelectedChannelType red, SelectedChannelType green, SelectedChannelType blue);
- @param channels array of channels in RGB order
void setRGBChannels(SelectedChannelType channels);
and all the code dealing with style parsing, encoding and rendering has enumerations or explicit mentions
of “red”, “green” and “blue”.
So public API breaking seems to be necessary, which implies that you’ll have to make a proposal and restrict
the code changes to the developer series:
http://docs.geotools.org/latest/developer/procedures/proposal.html
Hope this helps (even if it’s probably not what you wanted to hear :-p )
On Tue, Aug 22, 2017 at 8:41 PM, Danilo da Silveira Figueira <danilomalzao@anonymised.com> wrote:
I see that the property ChannelSelection has only RGB channels, i need to use all the RGBA channels.
In fact in my image the AlphaChannel is an important information too. And each cell has one different value, so because this i cant use things like RAMP/VALUE colormap.
It is possible to use something like in sld? If don’t, can i do this by implementing a geoserver extension?
i will have to
How can i do this?
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
