Thank you for your response. I didn’t think to try adding the profile to the Maven command. That seems to work. But having the profile selected in intellij does not. Or at least I can’t get that far.
I have had to do a few strange things to get to this point. One, I had to set bash on my path because the build fails without it when I use mvn or the intellij build option. Is there some sort of switch I should be using to turn this off? Otherwise, I get the below error.
Using the intellij build dialog it complains about many missing symbols. They appear to be about test class symbols. I put the errors below past the bash errors.
Thomas
Bash error
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-app —
[ERROR] Caught exception in FS.readPipe()
java.io.IOException: Cannot run program “bash” (in directory “C:\Users\thomas.harper.ctr”): CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at org.eclipse.jgit.util.FS.readPipe(FS.java:431)
at org.eclipse.jgit.util.FS_Win32.discoverGitPrefix(FS_Win32.java:113)
at org.eclipse.jgit.util.FS.gitPrefix(FS.java:517)
at org.eclipse.jgit.util.SystemReader$Default.openSystemConfig(SystemReader.java:92)
at org.eclipse.jgit.internal.storage.file.FileRepository.(FileRepository.java:171)
at org.eclipse.jgit.storage.file.FileRepositoryBuilder.build(FileRepositoryBuilder.java:92)
at pl.project13.maven.git.JGitProvider.getGitRepository(JGitProvider.java:265)
at pl.project13.maven.git.JGitProvider.init(JGitProvider.java:79)
at pl.project13.maven.git.GitDataProvider.loadGitData(GitDataProvider.java:91)
at pl.project13.maven.git.GitCommitIdMojo.loadGitDataWithJGit(GitCommitIdMojo.java:585)
at pl.project13.maven.git.GitCommitIdMojo.loadGitData(GitCommitIdMojo.java:558)
at pl.project13.maven.git.GitCommitIdMojo.execute(GitCommitIdMojo.java:376)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
at org.codehaus.classworlds.Launcher.main(Launcher.java:47)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 36 more
Missing test symbols
C:\Users\thomas.harper.ctr\source\geoserver\src\web\security\core\src\test\java\org\geoserver\security\web\AbstractSecurityWicketTestSupport.java
Error:(42, 35) java: cannot find symbol
symbol: class AbstractUserGroupServiceTest
Error:(56, 34) java: cannot find symbol
symbol: class XMLRoleServiceTest
Error:(57, 34) java: cannot find symbol
symbol: class XMLUserGroupServiceTest
Error:(77, 15) java: cannot find symbol
location: class org.geoserver.security.web.AbstractSecurityWicketTestSupport
Error:(127, 31) java: cannot find symbol
Error:(144, 24) java: cannot find symbol
Error:(144, 55) java: cannot find symbol
On Fri, Nov 23, 2018 at 4:24 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
That should work, the configuration which includes oauth2 in the webapp is indeed controlled by that profile (here).
Two suggestions:
- If you are running from maven, also include that profile when executing the run command, for example: “mvn jetty:run -Poauth2-github”
- If you are running from IntelliJ, ensure the oauth2-github profile is selected in the “Maven Projects” window.
Torben
On Wed, Nov 21, 2018 at 4:57 PM Thomas <tlann@anonymised.com> wrote:
I’m exploring building a geoserver extension that runs with my project’s oauth2 server. In that direction, I’m trying to get one of the original oauth2 community extensions built and working.
I’m building geoserver from within Intellij IDEA on a windows machine. I have chosen the profile oauth2-github in the maven projects dialog and built it using the execute maven goal using “clean install -DskipTests -Poauth2-github” It seems to build fine but I don’t see any indication the extension is built.
To start geoserver I use “jetty:run” and it starts up without issue. However, when going into the web console → authentication → add new authentication filters, the choices don’t include any oauth2 filters.
Is there any other sort of step I should be taking or log I should look at to help me resolve this?
~Thomas
Geoserver-devel mailing list
