I've gathered the security module of GS implements layer (and namespace) security, which is great... even greater would be to allow users to read only data within a certain bounding box: there are plans for it ? And, if not, how difficult would it be to implement such a check ?
Luca Morandini
www.lucamorandini.it
Ciao Luca,
if you check the history for this ml, someone already implemented it.
It might be interesting to get that code, review it and commit it.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, May 6, 2009 at 11:09 PM, Luca Morandini <lmorandini@anonymised.com> wrote:
Luca Morandini
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-devel mailing list
Simone Giannecchini wrote:
Ciao Luca,
Actually, this afternoon I searched this ML on this subject, to no avail... do you recall the time frame of this or the approximate title of the thread ?
Indeed
Luca Morandini
