OK, I have attached a new patch to GEOT-3615; with this GeoTools trunk build with -Dall:
https://jira.codehaus.org/browse/GEOT-3615
Unfortunately, GeoServer does not build with Maven 3. It will be a gigantic PITA to have to use Maven 3 for one and Maven 2 for another. I could not find an existing Geoserver Jira issue, so here is the one I created:
https://jira.codehaus.org/browse/GEOS-4652
Need a maven plugin guru to fix this mojo. Justin? Andrea?
Is it possible to get this to build on Maven 3 with breaking Maven 2?
On 29/06/11 10:10, Ben Caradoc-Davies wrote:
I've added +1 on the proposal.
I'm still seeing build failures with maven3. Please see the issue.
On 28/06/11 19:49, Jody Garnett wrote:
I should point out that we should be able to go ahead with the patch and proposal. At this point we have a couple of +1 votes...
- Andrea you indicated enthusiasm but did not vote? Anything to add...
- Ben how are you set to go on this?--
Jody GarnettOn Tuesday, 28 June 2011 at 9:02 PM, Michael Bedward wrote:
I guess it has to be experiment.
When Hudson runs a deploy job, time-stamped jars will end up in the
OSGeo repo. We only need to keep the most recent ones since this is
effectively what we were doing with non-timestamped jars.As far as I understand from the stackoverflow discussion, the problem,
if it still exists, affects the local repos of those using an eclipse
plugin (?). Supposedly, command line maven and (superior) NetBeans
users won't end up with multiple snapshots in their local repo... but
there's only one way to find out.Michael
On 28 June 2011 20:39, Jody Garnett<jody.garnett@anonymised.com<mailto:jody.garnett@anonymised.com>> wrote:
So Java 6 has gone out; meaning we can take up with maven 3 again.
So far the interesting question has been with respect to the handling of
SNAPSHOTS:
a) Justin will need to ask maven to clear out snapshots after a bit?
b) Developers should only have one snapshot jar; but there is some
discussion on if this feature is broken in maven 3 or not
Comments? Feedback? Experimentation?
JodyOn Thu, Jun 23, 2011 at 4:41 PM, Severin (aka Cliff)<djseverin@anonymised.com<mailto:djseverin@anonymised.com>>
wrote:Hi People,
I've written up a proposal on the wiki with regard to updating the
GeoTools build process to work under both Maven 2 and 3.
Justin: jgarnett suggested I open a dialogue with you to see if you have
any interest in updating the build box to use Maven 3 yet.
Proposal is
at http://docs.codehaus.org/display/GEOTOOLS/Update+to+use+Maven+3 for
review.Cheers,
Cliff
"We are dreamers, shapers, singers and makers..."------------------------------------------------------------------------------
Simplify data backup and recovery for your virtual environment with
vRanger.
Installation's a snap, and flexible recovery options mean your data is
safe,
secure and there when you need it. Data protection magic?
Nope - It's vRanger. Get your free trial download today.
http://p.sf.net/sfu/quest-sfdev2dev
Geotools-devel mailing list
Geotools-devel@lists.sourceforge.net<mailto:Geotools-devel@lists.sourceforge.net>
https://lists.sourceforge.net/lists/listinfo/geotools-devel------------------------------------------------------------------------------
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
