[Geoserver-devel] Extracting authentication credentials from headers
recently we worked on a custom AuthenticationFilter that uses request headers in a more sophisticated way than the standard request authentication filter does.
The main differences are:
  • the credentials (password) is extracted from request headers in addition to the username, so the filter is not preauthenticated, but uses the authentication providers chain to do the authentication
  • username and password can be extracted from a complex header value using a regular expression (one for each)
Our use case is to use the ability of frontends like Apache to forward credentials to the underlying Tomcat in a session header. This header is usually encrypted in browser to Apache communication, but sent in clear to the underlying Tomcat, so it can be easily parsed and used by Geoserver to fetch authentication data from Apache itself.
We would like to contribute the work done.
I was thinking of two possibile options:
  • a new community module
  • adding some configuration flags to the existing request header authentication filter to allow for:
  • optionally extracting the password and using the authentication providers chain to authenticate
  • specify regular expressions to extract the username (and optionally the password) from the header(s)
Any thoughts?
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Ciao Mauro,
please, see my commens inline below...
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Oct 9, 2014 at 10:47 AM, Mauro Bartolomeoli
<mauro.bartolomeoli@anonymised.com> wrote:
filter does.
- the credentials (password) is extracted from request headers in addition
- username and password can be extracted from a complex header value using
- a new community module
- adding some configuration flags to the existing request header
   * optionally extracting the password and using the authentication
   * specify regular expressions to extract the username (and optionally the
Any thoughts?
I am keen on the secondo option as I am always under the impression
that we have way too many extension modules and I would suggest to
avoid adding new one when needed/possible.
Mauro Bartolomeoli
@mauro_bart
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Hi Mauro
If I got it right, you want a filter to act as an end point for a pass through authentication. If this is the case, please create a new filter class or class hierarchy, your filter should be named “GeoServerPassThroughAuthEndPointFilter” or similar.
This class or class hierarchy should not be part of the hierarchy of preauthenticated filters, this would be confusing.
I am against a new community module, I would vote for adding this filter in the core code.
Christian
On Thu, Oct 9, 2014 at 10:55 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Mauro,
please, see my commens inline below…
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
<mauro.bartolomeoli@anonymised.com1268…> wrote:
filter does.
Any thoughts?
Mauro Bartolomeoli
@mauro_bart
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
2014-10-09 13:18 GMT+02:00 Christian Mueller <christian.mueller@anonymised.com>:
Hi Mauro
Uhm… I am not sure we need another hierarchy. I agree that this filter is not preauthenticated, so probably it deserves a distinct implementation.
Basically what it does is very similar to what BasicAuthentication or other filters do: fetch credentials in “some way” and then let the authentication manager do the authentication (this is what I meant when I said " uses the authentication providers chain to do the authentication").
My only concern is that some functionality could be useful also in the existing RequestHeader filter (for example the possibility to extract the username using a regular expression). Maybe we can put some common functionality in utility classes and use it from both filters, or just duplicate the code and don’t bother too much :).
Agree, then we need a name to distinguish this filter from the existing “HTTP Header”, something like “Credentials from HTTP Headers”. Ideas are welcome.
Mauro
@mauro_bart
Hi Mauro
In any case we should avoid code duplication and utility classes. I am fine with a distinct implementation too. “CredentialsFromHTTPHeader” sounds fine :slight_smile:
Go on, I assume you will make a pull request for discussion.
Christian
On Thu, Oct 9, 2014 at 2:57 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi Christian,
Hi Mauro
Mauro
@mauro_bart
I have prepared a pull request for this.
I chose to create a new filter in the main module, independent from the existing Request Headers filter.
Please, review if you wish.
Mauro
2014-10-09 15:24 GMT+02:00 Christian Mueller <christian.mueller@anonymised.com>:
Hi Mauro
Christian
Hi Christian,
Hi Mauro
Mauro
@mauro_bart
@mauro_bart
Hi Mauro
I did a quick review, looks good.
Christian
On Fri, Nov 7, 2014 at 4:40 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Mauro
Hi Mauro
Christian
@mauro_bart
On Thu, Oct 9, 2014 at 2:57 PM, Mauro Bartolomeoli <mauro.bartolomeoli@…1268…> wrote:
Hi Christian,
Hi Mauro
Mauro
@mauro_bart
