I have same issue on startup with geowebcache.
About of first build error, this works for me (and for test units):
“info.setUpdateSequence( (long) get( global, “updateSequence”, int.class ) );”
Best regards
Alvaro
De: Daniele Romagnoli daniele.romagnoli@anonymised.com
Para: A Huarte ahuarte47@anonymised.com
CC: Andrea Aime andrea.aime@anonymised.com; “geoserver-devel@lists.sourceforge.net” geoserver-devel@lists.sourceforge.net
Enviado: Lunes 21 de diciembre de 2015 17:41
Asunto: Re: [Geoserver-devel] Fail build LegacyConfigurationImporter in Eclipse mars for Windows and Java8…
I have same issue.
I was building GS master with maven using JDK 7, getting this:
[INFO] BUILD FAILURE
[INFO] Total time: 6.150 s
[INFO] Finished at: 2015-12-21T15:40:46+01:00
[INFO] Final Memory: 41M/369M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-platform: Compilation failure
[ERROR] Failure executing javac, but could not parse the error:
[ERROR] javac: invalid target release: 1.8
Therefore, I have switched to use Java8 and the maven build was fine.
Moving to eclipse (with Java 8 in the buildpath and 1.8 compiler compliance level), I got that compiling error.
So I have temporarly set 1.7 compiler compliance level to build.
At the moment I have a different issue with the startup (is creating an empty geowebcache-diskquota.xml file, resullting into an initialization error) but I think it’s not related to that. I’ll do some more checks on this.
Daniele
On Mon, Dec 21, 2015 at 3:20 PM, A Huarte <ahuarte47@anonymised.com> wrote:
Thanks Andrea, I will check this error when migration to Java 8 is completed.
I will still use Java7 until that day.
Alvaro
INFO:
Eclipse Java EE IDE for Web Developers (Mars.1 Release (4.5.1)) + Java™ SE Runtime Environment (build 1.8.0_66-b18) + Windows 7 x64:
All fine except only this simple error.
De: Andrea Aime <andrea.aime@anonymised.com>
Para: A Huarte <ahuarte47@anonymised.com>
CC: “geoserver-devel@anonymised.comsourceforge.net” <geoserver-devel@anonymised.comt>
Enviado: Lunes 21 de diciembre de 2015 14:25
You are probably wrong using Java 8, GeoServer is still supposed to be built with Java 7
Jokes aside, Ben is upgrading GeoServer to Java 8 in these days, and Eclipse has its own
compiler that sometimes different behavior than the official Java one.
I’d suggest to revisit once the migration to Java 8 on Maven + standard Java 8 has completed,
and then verify if there is any Eclipse specific oddity left.
In the meantime, I suggest you also get a JDK 7, that’s the one you will have to use to
verify anything for the 2.8.x and 2.7.x branches actually builds
On Mon, Dec 21, 2015 at 2:00 PM, A Huarte <ahuarte47@anonymised.com> wrote:
Hi, I have updated my geoserver repo to current master repo.
It builds ok from windows console with maven, but when I create the eclipse projects and I load them in Eclipse Mars (Windows 7 - x64), I get the error “Type mismatch: cannot convert from Integer to long” in line …
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/util/LegacyConfigurationImporter.java#L115
The current method of GeoServerInfo class accepts a long value:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/config/GeoServerInfo.java#L253
I can change the code to:
info.setUpdateSequence( get( global, “updateSequence”, int.class ) );
Eclipse builds ok, but really where I am wrong?
Thanks in advance.
Alvaro
Geoserver-devel mailing list
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ing. Daniele Romagnoli
Senior Software Engineer
