Oh sorry I mean the Geoserver RC 2.2:
Geoserver Version = Bloglink -> http://blog.geoserver.org/ / https://sourceforge.net/projects/geoserver/files/GeoServer/2.2-RC2/
With Plugins (http://gridlock.opengeo.org/geoserver/2.2.x/):
excel / sqlserver / wps = normal ext. +
inspire / monitor / printing = Community
Today I even updated all Plugins that was created last night.
But GWC still doesn’t seed.
I used 10 different virtual workspaces with several vector (point/polygon) layers, own and implemented sld's. But there is the same log message for all of them and it isn't successful.
What does this "NoSuchAuthorityCodeException" ' "AUTHORITY:NUMBER" mean?
AUTHORITY = AUTHORITYCode for GetCapabilities Metadata or for the new Security Implementation?
2012-08-10 08:46:49,720 INFO [seed.SeedTask] - GWC Seeder Thread-4 begins seeding layer : Miesmuschel:Miesmuschelbank_2002_ETRS_89
2012-08-10 08:46:49,723 INFO [geoserver.wms] -
Request: getServiceInfo
2012-08-10 08:46:49,723 ERROR [geoserver.ows] -
org.opengis.referencing.NoSuchAuthorityCodeException: No authority was defined for code "20037508,34,20037508,34". Did you forget "AUTHORITY:NUMBER"?
at org.geotools.referencing.factory.ManyAuthoritiesFactory.noSuchAuthority(ManyAuthoritiesFactory.java:489)
at org.geotools.referencing.factory.ManyAuthoritiesFactory.getAuthorityFactory(ManyAuthoritiesFactory.java:467)
at org.geotools.referencing.factory.ManyAuthoritiesFactory.getCRSAuthorityFactory(ManyAuthoritiesFactory.java:548)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:800)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:489)
at org.geotools.referencing.CRS.decode(CRS.java:417)
at org.geoserver.wfs.kvp.BBoxKvpParser.parse(BBoxKvpParser.java:74)
at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:453)
at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1386)
at org.geoserver.ows.Dispatcher.init(Dispatcher.java:319)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:243)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1037)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:523)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:498)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:662)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:129)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
2012-08-10 08:46:49,725 INFO [seed.GWCTask] - Thread group finished SEED task after 0.011 seconds
2012-08-10 08:46:49,725 ERROR [seed.MTSeeder] - Problem communicating with GeoServer
org.geowebcache.GeoWebCacheException: Problem communicating with GeoServer
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:503)
Caused by: java.lang.IllegalStateException: Expected: RenderedImageMap, got null
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:526)
... 10 more
Mit freundlichen Grüßen
Im Auftrag
Michael Räder
______________________________________________
Michael Räder
Nationalpark-Verwaltung Niedersächsisches Wattenmeer
Virchowstr. 1 / 26382 Wilhelmshaven
Tel.: +49 (0) 4421 911 295 / Fax.: +49 (0) 4421 911 280
Email: michael.raeder@...3245...
║ [NLPV] ║ [MDI - DE] ║
Von: Gabriel Roldan [mailto:groldan@…1501…]
Gesendet: Donnerstag, 9. August 2012 19:49
An: Räder, Michael
Cc: geoserver-devel@lists.sourceforge.net
Betreff: Re: [Geoserver-devel] Failed to create GWC RC_2.2
Ugh, that looks bad. Would you make it clear how to reproduce? Exact
GeoServer version? (GWC RC_2.2 is confusing, there's no such thing) Or
you mean GeoSever 2.2-RCXX?
and does it happen with any layer? when trying to seed through the gwc
seed form?
On Thu, Aug 9, 2012 at 5:26 AM, Räder, Michael
.../geoserver/gwc/rest/seed/<Layername>
No function for seed/reseed Layer GWC
Delete GWC that was create by older Geoserver is possible.
2012-08-09 10:22:30,241 INFO [seed.SeedTask] - GWC Seeder Thread-2 begins seeding layer : Eiderente:eider01_1991_ETRS_89
2012-08-09 10:22:30,250 INFO [geoserver.wms] -
2012-08-09 10:22:30,250 ERROR [geoserver.ows] -
org.opengis.referencing.NoSuchAuthorityCodeException: No authority was defined for code "180,0,90,0". Did you forget "AUTHORITY:NUMBER"?
2012-08-09 10:22:30,252 INFO [seed.GWCTask] - Thread group finished SEED task after 0.011 seconds
2012-08-09 10:22:30,252 ERROR [seed.MTSeeder] - Problem communicating with GeoServer
... 10 more
2012-08-09 10:22:32,614 INFO [geoserver.wms] -
Im Auftrag
Michael Räder
Michael Räder
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
