The hz-cluster and monitor-hibernate community modules were removed from the community build (communityRelease profile and build descriptor in community/pom.xml) shortly after the Java 11 update (as they were failing to build).
Just as an update, I’ve now also removed these modules from community/release/pom.xml
as that had not yet been done.
And as a reminder:
a) When commenting out a module from the communityRelease profile in community/pom.xml please also do the same in community/release/pom.xml so that we don’t accidentally get old versions of the module showing up in the release/nightlies.
b) once these modules do get fixed also remember to restore the module in both places.
Torben
