I send the following request to geoserver:
http://localhost:8080/geoserver/GetFeature?FEATUREID=RQS_POINT.9
I see the point, that the format must be .. But the generated sql statement contains:
WHERE FID=‘RQS_POINT.9’
The FID column is a number, that’s why the above request throws an exception. It should be something like:
select … from RQS_POINT where FID=‘9’ …
Is this a problem of the OracleDataSource or is it the way it is intended to work?
Simon Räss
This looks like an OracleDataSource bug. Ill put a fix in for it when I get to work tomorrow.
Thanks
Sean
I see the point, that the format must be <feature-type-name>.<id>. But the generated sql statement contains:
WHERE FID='RQS_POINT.9'
The FID column is a number, that's why the above request throws an exception. It should be something like:
select ... from RQS_POINT where FID='9' ...
Simon Räss
