[Geoserver-devel] Feedbacks needed on SecurityNamedServiceEditPage logic
Dear all,
currently the “SecurityNamedServiceEditPage” is used by GeoServer in order to edit the configuration of a defined security filter.
Such class searches for "AuthenticationFilterPanelInfo"s related to a specific AuthFilter and instantiates the model for Wicket in order to allow the admin to edit the configuration info.
Now, each “AuthenticationFilterPanelInfo” is defined by 3 properties:
  • setComponentClass; the Class of the concrete Wicket Panel
  • setServiceClass; the Class of the target AuthFilter
  • setServiceConfigClass; the Class of the XStream Configuration
The problem is the following one:
the “lookupPanelInfo” method of the “SecurityNamedServiceEditPage” looks only for the ServiceClass and ignores completely the ServiceConfigClass.
try {
serviceClass = Class.forName(config.getClassName());
} catch (ClassNotFoundException e) {
throw new RuntimeException(e);
if (l.size() == 1) {
//filter down to one match
return l.get(0);
throw new RuntimeException("Found multiple panel infos for service config: " + config
  • ", service class: " + serviceClass);
The side effect is that whenever I have two different AuthProvider defined by two different ServiceConfigClass but referring to the same ServiceClass (see for instance the OAuth2 Providers which share exactly the same Filter logic but have different configurations for different OAuth2 providers) I won’t be able to edit them via GUI anymore.
Consider the use case when I want to enable both Google and GitHub OAUth2 providers on GeoServer. Accordingly to this I basically should duplicate both the AuthProvider and AuthFilter classes, even if they do exactly the same thing.
My question is: “Is there a particular reason for such behavior of the editor page?”
NOTICE also that:
  1. Create new AuthProviders referring to the same ServiceClass is currently possible on GeoServer
  2. We will have the same issue in the case we create two (or more) different configurations for the same AuthProvider too
Any thoughts on that? Anyone knows a good reason to not allowing the “SecurityNamedServiceEditPage” to check also for the ServiceConfigClass?
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Hi Alessio
Long story for short. At the time when Justin an me invented this design we did not consider such constellations. Feel free to improve where it is possible.
Christian
On Thu, Oct 27, 2016 at 4:44 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear all,
try {
return l.get(0);
NOTICE also that:
Best Regards,
Alessio Fabiani.
@alfa7691
The Command Line: Reinvented for Modern Developers
Did the resurgence of CLI tooling catch you by surprise?
Reconnect with the command line and become more productive.
Learn the new .NET and ASP.NET CLI. Get your free copy!
http://sdm.link/telerik
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
