Hi list,
As you know, I’m working on a geotools improvement (see 1 for the proposal) to allow delete on Structured GridCoverage Readers.
I would like to integrate this capability in GeoServer through REST delete coverageStore call 2:
On such a topic I was thinking about adding a new parameter beside the “recurse” one 3 for the delete op.
Something like “delete” which may have 3 values:
none → default… to be backward compatible with the current REST delete store behaviour)
metadata → in order to delete only metadata, and auxiliary files… no granules will be deleted)
all → in order to delete everything. This will be related to the reader.delete(true) call which will also delete granules.
What do you think about it?
Suggestions for better parameter name and value names are also greatly appreciated.
I will open a JIRA with the outcome of the discussion.
Please, let me know.
Best Regards,
Daniele
== GeoSolutions will be closed for Christmas Holidays from 23/12/2013 to 06/01/2014 ==
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hey Daniele,
Not sure if there was any movement one this but +1 from me. The only suggestion from a naming standpoint would be to make the parameter named “purge”, rather than “delete”.
-Justin
On Wed, Dec 18, 2013 at 10:41 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi list,
Best Regards,
Daniele
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Geoserver-devel@anonymised.comt
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Thanks for your feedback Justin,
I have created a JIRA for that, including your “purge” parameter suggestion.
Daniele
On Mon, Jan 6, 2014 at 6:49 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hey Daniele,
-Justin
Hi list,
Best Regards,
Daniele
Justin Deoliveira
@j_deolive
