[Geoserver-devel] Fiddling with autocomplete drop downs in the UI
one of the things that keeps on annoying me with the current UI is how hard it is, sometimes,
to locate an item in dropdown, especially when they get long.
The two major pet-peeves of mine are the “new layer/choose store” and “layer/publishing/default style”
cases, it is not uncommon to have hundreds of entries in there, and locating things in there when
one just remembers the store name but not the workspace, or just part of the name, can be rather
time consuming.
So I wanted to do something about it (without getting nuts and trying to handle the hundreds of
thousands choices cases, that would require a different treatment and more effort).
Looking around I’ve found this wicketstuff-select2 component that provides a autocomplete dropdown
based on https://select2.org/, see https://select2.org/getting-started/basic-usage for examples.
I wanted something that would be a drop-in replacement for the Wicket DropDownChoice, so made
a small bridge class, and something that would not look too much out of place, so worked a bit
on the style too.
I came up with this, here are a couple of videos showing it in action on the default data directory
(which does not have many items, but hope you get the idea anyways):
https://drive.google.com/open?id=1u9Zeb1gs0N3ps-H5SgeGDsbsJ-Sf3zFH
https://drive.google.com/open?id=1nv458H0PbzVMskzqQxaFmWF0l5GqVVq3
The downside of these new combos is that they do not look like native ones in Firefox for example:
https://drive.google.com/open?id=1RCYwfthUb79rhxnRrT0x7AP1hDXeC7i1
Now, we could just replace all dropdowns with autocomplete ones… seems a bit silly for dropdowns
having 3 items in it, but would at least be consistent style and UI experience wise.
Here is a pull request so that you can see how it looks code wise, as you can see most of the time
switching to the autocomplete version of the drop down is a “search and replace” business:
https://github.com/geoserver/geoserver/pull/2716
So… thoughts?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
UI improvements are always nice, and this seems like a particularly useful one.
The style differences relative to native drop-downs are a bit annoying, but seem fine. One possible alternate workaround for that would be to style the regular drop-downs so that they are the same between browsers. That should be as simple as adding a bit of CSS (Although most of the methods I could find for this used a background image to replace the select, so this workaround seems a bit finicky).
I think we should probably avoid replacing all drop-downs with the select2 one just for style reasons, seems like it could be a bit annoying/unnecessary where there are only a few options.
One thing I did notice is that the select2 drop-down doesn’t support keyboard navigation (tab + arrow keys), unlike a regular select. That seems like another good reason to only use it where necessary.
Looking at the code, it seems pretty straightforward and easy to use. Overall, +1.
Torben
On Sun, Jan 14, 2018 at 2:52 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
time consuming.
on the style too.
So… thoughts?
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
+1
On 01/14/2018 10:52 AM, Andrea Aime wrote:
time consuming.
on the style too.
So… thoughts?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Mon, Jan 15, 2018 at 7:06 PM, Torben Barsballe <
one.
Indeed... I looked around but could not find an approach that would scale
well along the the base system font size changes... (there are some
bootstrap based examples that might work, but we don't use bootstrap in
GeoServer so...).
Can you think of any other case in the UI that would benefit from having
the select2 list?
Yeah, I was wondering myself. Personally I'd prefer visual consistency but
I have no strong opinion on this one, happy to leave it as is.
One thing I did notice is that the select2 drop-down doesn't support
That is indeed annoying (although not sure how keyboard friendly the UI is
to start with).
Hmmm... seems like it may be fixable, I'll have a look into it:
https://github.com/select2/select2/issues/3472
Overall, +1.
Thanks!
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Jan 21, 2018 at 10:07 AM, Andrea Aime <andrea.aime@anonymised.com>
useful one.
GeoServer so...).
Ah, forgot about scaling; yeah that would make things rather more difficult.
the select2 list?
Hmm... List of requests on the Demo requests page. Likewise, list of WPS
processes on the WPS request builder demo. Preview format on Layer Preview
page.
You could maybe change the CRS fields on the Layer / Layer group edit page
to use it, but that seems like a bit more work.
to start with).
From what I have seen / tried, navigating by keyboard is a bit finicky, but
still technically doable.
Arrow keys do not change value of select · Issue #3472 · select2/select2 · GitHub
If a viable fix comes out of that, then I wouldn't see an issue with
replacing all select boxes with the select2 one. As-is, I think the
accessibility improvement of the regular select boxes outweighs the style
consistency.
Torben
Hi folks,
pull request updated and now in a stable that I’d be comfortable merging:
https://github.com/geoserver/geoserver/pull/2744
Updates:
  • Simplified the code significantly, relying mostly on select2 auto-magic conversion on an existing select
  • The Select2DropDownChoice is now a DropDownChoice subclass, so removed the extra special testing code
  • Added code to mimick native drop down keyboard behavior. It’s not 100% the same, but got as close as possible (the one deviation that I’m aware of, if you type in a closed native select it will take into account all chars you typed to select the best match, this version only looks for the first one, e.g., has no state).
  • Added more select2 based drop downs around, but only for long lists (mostly based on Torbens’ suggestions, but could not easily migrate the preview one)
    I did not do a full migration, as I don’t have time to test all pages one by one, but I guess we can switch pages a bit at a time, also based on actual need?
The code is fully javascript in the end, so not testable in WicketTester. I’ve done my best to test by hand, other testers more than welcomed :slight_smile:
On Mon, Jan 22, 2018 at 8:05 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
On Sun, Jan 21, 2018 at 10:07 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Hmm… List of requests on the Demo requests page. Likewise, list of WPS processes on the WPS request builder demo. Preview format on Layer Preview page.
You could maybe change the CRS fields on the Layer / Layer group edit page to use it, but that seems like a bit more work.
From what I have seen / tried, navigating by keyboard is a bit finicky, but still technically doable.
If a viable fix comes out of that, then I wouldn’t see an issue with replacing all select boxes with the select2 one. As-is, I think the accessibility improvement of the regular select boxes outweighs the style consistency.
Torben
On Mon, Jan 15, 2018 at 7:06 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Indeed… I looked around but could not find an approach that would scale well along the the base system font size changes… (there are some
bootstrap based examples that might work, but we don’t use bootstrap in GeoServer so…).
Can you think of any other case in the UI that would benefit from having the select2 list?
Yeah, I was wondering myself. Personally I’d prefer visual consistency but I have no strong opinion on this one, happy to leave it as is.
That is indeed annoying (although not sure how keyboard friendly the UI is to start with).
Hmmm… seems like it may be fixable, I’ll have a look into it: https://github.com/select2/select2/issues/3472
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
