[Geoserver-devel] Filter resquest goes wrong
Hi folks,
I have tried some requests to test my wfs server based on geoserver 1.1 and
running on tomcat 4.1.30:
Test 1 - Filter (Area Of Interest)
Query all properties of all feature instances of the feature type LOCATORS
that lie within the specified box
http://localhost:8080/GridRetriever/wfs?request=GetFeature&typename=locators
&filter=<Filter%20xmlns="http://www.opengis.net/ogc&quot;%20xmlns:gml=&quot;http://www
.opengis.net/gml"><Within><PropertyName>locators/the_geom</PropertyName><gml
:Box><gml:coordinates>-120,30%200,80</gml:coordinates></gml:Box></Within></F
ilter>
Works fine! So, a filter with the Within operator seems to work properly...
Test 2 - Filter (location name)
where the location name is 'Toronto'
&filter=<Filter><PropertyIsEqualTo><PropertyName>loc_name</PropertyName><Lit
eral>Toronto</Literal></PropertyIsEqualTo></Filter>
Works fine!!
Test 3 - Filter (country code)
where the code name is 'CA'
&filter=<Filter><PropertyIsEqualTo><PropertyName>country_code</PropertyName>
<Literal>CA</Literal></PropertyIsEqualTo></Filter>
Works fine!!!
Test 4 - Filter(location name + country code)
where the location name is 'Toronto' and the country code is 'CA'
&filter=<Filter%20xmlns="http://www.opengis.net/wfs&quot;%20xmlns:ogc=&quot;http://www
.opengis.net/ogc"%20xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;And&gt;&lt;PropertyIsE
qualTo><PropertyName>country_code</PropertyName><Literal>CA</Literal></Prope
rtyIsEqualTo><PropertyIsEqualTo><PropertyName>loc_name</PropertyName><Litera
l>Toronto</Literal></PropertyIsEqualTo></And></Filter>
Works fine!!!! So, a filter with the And operator seems to work properly...
Test 5 - Filter(AOI + loc_name)
that lie within the specified box and where the location name is 'Toronto'
.opengis.net/ogc"%20xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;And&gt;&lt;Within&gt;&lt;Pro
pertyName>locators/the_geom</PropertyName><gml:Box><gml:coordinates>-74,44%-
68,47</gml:coordinates></gml:Box></Within><PropertyIsEqualTo><PropertyName>l
oc_name</PropertyName><Literal>Toronto</Literal></PropertyIsEqualTo></And></
Filter>
Error returned by the server:
java.lang.IllegalStateException: getOutputStream() has already been called
for this response
  at
org.apache.coyote.tomcat4.CoyoteResponse.getWriter(CoyoteResponse.java:600)
  at
org.apache.coyote.tomcat4.CoyoteResponseFacade.getWriter(CoyoteResponseFacad
e.java:171)
  at
org.vfny.geoserver.servlets.AbstractService.send(AbstractService.java:446)
  at
org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:4
87)
  at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:3
63)
  at
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:195)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
  at
org.vfny.geoserver.servlets.wfs.WfsDispatcher.doResponse(WfsDispatcher.java:
159)
  at
org.vfny.geoserver.servlets.wfs.WfsDispatcher.doGet(WfsDispatcher.java:112)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Application
FilterChain.java:247)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterCh
ain.java:193)
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.ja
va:256)
  at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invok
eNext(StandardPipeline.java:643)
  at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
  at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.ja
va:191)
  at
  at
  at
  at
org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2422)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180
  at
  at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.
java:171)
  at
eNext(StandardPipeline.java:641)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:163
  at
  at
  at
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java
:174)
  at
  at
  at
  at
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:199)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:828)
  at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConne
ction(Http11Protocol.java:700)
  at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:584)
  at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.jav
a:683)
  at java.lang.Thread.run(Thread.java:534)
What is wrong with this request???
Please help!
Thanks in advance,
Marc
Hmmm... Do you have the logs? This is hard to diagnose because the
problem is likely when executing the database query (what backend are you
using? That would be helpful as well), so it sends a very unhelpful
error. The logs should probably shed more information, or alternatively
you can set the serviceStrategy param in WEB-INF/web.xml to FILE instead
of SPEED (in 1.2.3 this can be accomplished with the web admin interface,
setting config -> server -> verboseExceptions to true). You also may try
doing the property name as just 'the_geom' instead of 'locaters/the_geom',
as that's how I usually do requests. You also may try upgrading to 1.2,
though I don't remember any fixes of this nature there has been a lot of
work done since 1.1. But if you get the logs I can probably diagnose, see
if it's a problem with the request or a bug in the code).
best regards,
Chris
----- Original Message -----
From: "Morin, Marc-André" <Marc-Andre.Morin@anonymised.com>
To: <geoserver-devel@lists.sourceforge.net>
Sent: Wednesday, November 17, 2004 1:58 PM
Subject: [Geoserver-devel] Filter resquest goes wrong
Hi folks,
and
LOCATORS
ilter>
properly...
LOCATORS
Works fine!!
LOCATORS
Works fine!!!
LOCATORS
properly...
LOCATORS
'Toronto'
Filter>
called
for this response
at
at
e.java:171)
at
at
87)
at
63)
at
at
159)
at
at
at
ain.java:193)
at
va:256)
at
at
at
at
va:191)
at
at
at
at
at
at
at
java:171)
at
at
at
at
at
at
:174)
at
at
at
at
at
at
at
at
a:683)
Please help!
Thanks in advance,
Marc
