[Geoserver-devel] Filter with PostGIS table and Shape file
  Is anybody get the filter work with the PostGIS table?I seems not work
with me. I use the same SLD file test with the shapefile. It works. But
not work with PostGIS tables. Any suggestions to me?
  Thank you very much.
  Rong.
Below the SLD with filter inside.
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
<!-- a named layer is the basic building block of an sld document -->
<NamedLayer>
<Name>A Test Layer</Name>
<!-- with in a layer you have Named Styles -->
<UserStyle>
    <!-- again they have names, titles and abstracts -->
  <Name>population</Name>
  <Title>Population in the United States</Title>
  <Abstract>A sample filter that filters the United States into three
            categories of population, drawn in different colors</Abstract>
    <FeatureTypeStyle>
      <Rule>
        <!-- like a linesymbolizer but with a fill too -->
        <ogc:Filter xmlns:gml="http://www.opengis.net/gml&quot;&gt;
          <ogc:PropertyIsBetween>
            <ogc:PropertyName>PERSONS</ogc:PropertyName>
            <ogc:LowerBoundary>
              <ogc:Literal>2000000</ogc:Literal>
            </ogc:LowerBoundary>
            <ogc:UpperBoundary>
              <ogc:Literal>4000000</ogc:Literal>
            </ogc:UpperBoundary>
          </ogc:PropertyIsBetween>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
              <!-- CssParameters allowed are fill (the color) and
fill-opacity -->
              <CssParameter name="fill">#FF0000</CssParameter>
           </Fill>
        </PolygonSymbolizer>
      </Rule>
      <Rule>
          <ogc:PropertyIsLessThan>
          </ogc:PropertyIsLessThan>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
              <CssParameter name="fill">#00FF00</CssParameter>
           </Fill>
      </Rule>
      <Rule>
          <ogc:PropertyIsGreaterThan>
          </ogc:PropertyIsGreaterThan>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
              <CssParameter name="fill">#0000FF</CssParameter>
           </Fill>
      </Rule>
      <Rule>
        <LineSymbolizer>
           <Stroke/>
        </LineSymbolizer>
      </Rule>
    </FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Sounds like it could be case sensitivity, try lower cases for your
property names.
Chris
Quoting rong@anonymised.com:
work
But
  Rong.
<NamedLayer>
<UserStyle>
colors</Abstract>
    <FeatureTypeStyle>
      <Rule>
            <ogc:LowerBoundary>
            <ogc:UpperBoundary>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
           </Fill>
      </Rule>
      <Rule>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
           </Fill>
      </Rule>
      <Rule>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
           </Fill>
      </Rule>
      <Rule>
        <LineSymbolizer>
           <Stroke/>
        </LineSymbolizer>
      </Rule>
    </FeatureTypeStyle>
</UserStyle>
</NamedLayer>
SF.Net email is sponsored by: Discover Easy Linux Migration
Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_idt77&alloc_id492&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
Yes. I tried the lower case for POstGIS table.It doesn't work. The upper
case is for the shape file. The SLD files are the same for the db table
and shapefile except this little difference.(lower case for db table and
upper case for shapefile).
property names.
Chris
work
But
  Rong.
<NamedLayer>
<UserStyle>
colors</Abstract>
    <FeatureTypeStyle>
      <Rule>
            <ogc:LowerBoundary>
            <ogc:UpperBoundary>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
           </Fill>
      </Rule>
      <Rule>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
           </Fill>
      </Rule>
      <Rule>
        </ogc:Filter>
        <PolygonSymbolizer>
           <Fill>
fill-opacity -->
           </Fill>
      </Rule>
      <Rule>
        <LineSymbolizer>
           <Stroke/>
        </LineSymbolizer>
      </Rule>
    </FeatureTypeStyle>
</UserStyle>
</NamedLayer>
Strategies
Could you set the logging to at least fine and get at the logs? Then we
can look at what is actually being sent to the postgis (also I'm going
to bed right now, so I probably won't answer for awhile).
Chris
upper
table
and
> property names.
> Chris
>> Hi,
not
>> work
works.
>> But
>> Rong.
>> <NamedLayer>
>> <UserStyle>
three
>> colors</Abstract>
>> <FeatureTypeStyle>
>> <Rule>
>> <ogc:LowerBoundary>
>> <ogc:UpperBoundary>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> <LineSymbolizer>
>> <Stroke/>
>> </LineSymbolizer>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>> Strategies
articles,
to
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
OK, I'll try to get logs and see what actually happened. Thanks and Good
night.
Chris
upper
table
and
> property names.
> Chris
>> Hi,
not
>> work
works.
>> But
>> Rong.
>> <NamedLayer>
>> <UserStyle>
three
>> colors</Abstract>
>> <FeatureTypeStyle>
>> <Rule>
>> <ogc:LowerBoundary>
>> <ogc:UpperBoundary>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> <LineSymbolizer>
>> <Stroke/>
>> </LineSymbolizer>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>> Strategies
articles,
to
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
  Below is the log for one request.
611079 [FINE] org.vfny.geoserver.util.requests.readers.KvpRequestReader -
clean request is
bbox=219638.0,3655299.0,285173.0,3720834.0&styles=yield_db&Format=image/png&request=GetMap&layers=topp:yield&width=2200&height=1000&srs=EPSG:26914
returning parsed {SRS=EPSG:26914, LAYERS=topp:yield,
BBOX=219638.0,3655299.0,285173.0,3720834.0, HEIGHT=1000, REQUEST=GetMap,
STYLES=yield_db, WIDTH=2200, FORMAT=image/png}
611094 [INFO] org.vfny.geoserver.servlets.AbstractService - Looking for
configured service responses' strategy
611110 [INFO] org.vfny.geoserver.servlets.AbstractService - Looking for
configured service strategy SPEED
611110 [FINE] org.vfny.geoserver.servlets.AbstractService - verifying
configured strategy
611125 [INFO] org.vfny.geoserver.servlets.AbstractService - Using service
strategy class org.vfny.geoserver.servlets.SpeedStrategy
611125 [FINE] org.vfny.geoserver.servlets.AbstractService - reading
request:
611141 [FINE] org.vfny.geoserver.global.Data - getting type topp:yield
611157 [FINE] org.geotools.data.postgis.PostgisDataStore - get Feature
source called on yield
611157 [FINE] org.geotools.data.postgis.PostgisDataStore - returning pg
feature locking
611157 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
611172 [FINE] org.vfny.geoserver.wms.requests.GetMapKvpReader -
establishing yield_db style for topp:yield
611172 [INFO] org.vfny.geoserver.servlets.AbstractService - handling
request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
611188 [FINE] org.vfny.geoserver.servlets.AbstractService - strategy is:
org.vfny.geoserver.servlets.SpeedStrategy@anonymised.com
611219 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - setting
up map
611235 [FINE] org.geotools.data.postgis.PostgisDataStore - get Feature
611235 [FINE] org.geotools.data.postgis.PostgisDataStore - returning pg
feature locking
611250 [FINE] org.vfny.geoserver.wms.responses.DefaultRasterMapProducer -
setting up 2200x1000 image
611344 [FINE] org.vfny.geoserver.wms.responses.DefaultRasterMapProducer -
calling renderer
611360 [FINE] org.geotools.renderer.lite.LiteRenderer2 - Affine Transform
is AffineTransform[[0.033569848172732, 0.0, -7373.214312962539], [0.0,
-0.015259021896696, 56776.28747997254]]
611375 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
611375 [FINE] org.geotools.renderer.lite.LiteRenderer2 - added attribute
plant_key
611391 [FINE] org.geotools.renderer.lite.LiteRenderer2 - added attribute
the_geom
611391 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
611407 [FINE] org.geotools.renderer.lite.LiteRenderer2 - processing 1
stylers
611407 [FINE] org.geotools.renderer.lite.LiteRenderer2 - processing style 0
611422 [FINE] org.geotools.renderer.lite.LiteRenderer2 - processing rule 0
611422 [FINE] org.geotools.data.jdbc.JDBCDataStore - calling sql builder
with filter [ the_geom bbox POLYGON ((219638 3655299, 219638 3720834,
285173 3720834, 285173 3655299, 219638 3655299)) ]
611438 [FINE] org.geotools.data.jdbc.JDBCDataStore - sql is SELECT "oid",
"the_yield", "plant_key", bytea(AsBinary(force_2d("the_geom"), 'XDR'))
FROM "yield" WHERE "the_geom" && GeometryFromText('POLYGON ((219638
3655299, 219638 3720834, 285173 3720834, 285173 3655299, 219638
3655299))', 26914)
611454 [FINE] org.geotools.data.jdbc.JDBCDataStore - About to execute
query: SELECT "oid", "the_yield", "plant_key",
bytea(AsBinary(force_2d("the_geom"), 'XDR')) FROM "yield" WHERE
"the_geom" && GeometryFromText('POLYGON ((219638 3655299,219638 3720834,
285173 3720834, 285173 3655299, 219638 3655299))', 26914)
611469 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
623532 [FINE] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager
- Connection closed - adding to available connections.
623548 [FINE] org.geotools.renderer.lite.LiteRenderer2 - Style cache hit
ratio: 0.9998779315501167 , hits 65529, requests 65537
623563 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type is:
image/png
628017 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
And my Rule is as below:
          <ogc:PropertyName>the_yield</ogc:PropertyName>
          <ogc:Literal>100</ogc:Literal>
</ogc:Filter>
night.
Chris
upper
table
and
> property names.
> Chris
>> Hi,
not
>> work
works.
>> But
>> Rong.
>> <NamedLayer>
>> <UserStyle>
three
>> colors</Abstract>
>> <FeatureTypeStyle>
>> <Rule>
>> <ogc:LowerBoundary>
>> <ogc:UpperBoundary>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> <LineSymbolizer>
>> <Stroke/>
>> </LineSymbolizer>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>> Strategies
articles,
to
Hi,Chris,
  I did more tests.I found the wfs fileter is OK. The wms with sld is not
OK.The wfs can attache the filter as a "where" condition for the sql
statement. But the sld cannot.
clean request is
configured strategy
request:
feature locking
up map
feature locking
calling renderer
plant_key
the_geom
stylers
0
0
3655299))', 26914)
connection.
image/png
handled
</ogc:Filter>
night.
we
Chris
upper
table
and
> property names.
> Chris
>> Hi,
not
>> work
works.
>> But
>> Rong.
>> <NamedLayer>
>> <UserStyle>
three
>> colors</Abstract>
>> <FeatureTypeStyle>
>> <Rule>
>> <ogc:LowerBoundary>
>> <ogc:UpperBoundary>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> </ogc:Filter>
>> <PolygonSymbolizer>
>> <Fill>
>> fill-opacity -->
>> </Fill>
>> </Rule>
>> <Rule>
>> <LineSymbolizer>
>> <Stroke/>
>> </LineSymbolizer>
>> </Rule>
>> </FeatureTypeStyle>
>> </UserStyle>
>> </NamedLayer>
>> Strategies
articles,
to
What version are you working against? Go ahead and report it as a bug?
http://jira.codehaus.org/secure/BrowseProject.jspa?id=10311 And it's
just postgis? With Shapefiles SLD+Filters work fine? But with PostGIS
they don't? That seems odd. We'll look into it.
Chris
Hi,Chris,
not
> Hi,
> 611079 [FINE]
> clean request is
> 611079 [FINE]
REQUEST=GetMap,
Looking for
Looking for
verifying
> configured strategy
service
reading
> request:
topp:yield
Feature
returning pg
> feature locking
handling
strategy is:
setting
> up map
Feature
returning pg
> feature locking
> 611250 [FINE]
> 611344 [FINE]
> calling renderer
Transform
[0.0,
attribute
> plant_key
attribute
> the_geom
processing 1
> stylers
processing style
> 0
processing rule
> 0
builder
3720834,
"oid",
'XDR'))
> 3655299))', 26914)
execute
3720834,
available
> connection.
> 623532 [FINE]
cache hit
type is:
> image/png
Service
> handled
> </ogc:Filter>
and Good
>> night.
Then
>>> we
going
>>> Chris
The
>>>> upper
db
>>>> table
table
>>>> and
your
>>>> > property names.
>>>> > Chris
>>>> >> Hi,
seems
>>>> not
>>>> >> work
>>>> works.
>>>> >> But
>>>> >> Rong.
document
>>>> >> <NamedLayer>
>>>> >> <UserStyle>
into
>>>> three
>>>> >> colors</Abstract>
>>>> >> <FeatureTypeStyle>
>>>> >> <Rule>
>>>> >> <ogc:LowerBoundary>
>>>> >> <ogc:UpperBoundary>
>>>> >> </ogc:Filter>
>>>> >> <PolygonSymbolizer>
>>>> >> <Fill>
and
>>>> >> fill-opacity -->
>>>> >> <CssParameter
>>>> >> </Fill>
>>>> >> </Rule>
>>>> >> <Rule>
>>>> >> </ogc:Filter>
>>>> >> <PolygonSymbolizer>
>>>> >> <Fill>
and
>>>> >> fill-opacity -->
>>>> >> <CssParameter
>>>> >> </Fill>
>>>> >> </Rule>
>>>> >> <Rule>
>>>> >> </ogc:Filter>
>>>> >> <PolygonSymbolizer>
>>>> >> <Fill>
and
>>>> >> fill-opacity -->
>>>> >> <CssParameter
>>>> >> </Fill>
>>>> >> </Rule>
>>>> >> <Rule>
>>>> >> <LineSymbolizer>
>>>> >> <Stroke/>
>>>> >> </LineSymbolizer>
>>>> >> </Rule>
>>>> >> </FeatureTypeStyle>
>>>> >> </UserStyle>
>>>> >> </NamedLayer>
>>>> >> Strategies
>>>> articles,
up
>>>> to
>>>> >> speed, fast.
Strategies
articles,
to
>>> speed, fast.
Strategies
articles,
to
Strategies
Strategies
I tested all latest version(1.30-beta3, 1.3.0-beta4,1.3.0-RC1). I'll
report this as bug. Then I'll also setup the development and try to debug
it by myself. By the way, Is it possible for me to send wfs request with
the filter using the sld file for wms? Is this a work-around way for this
problem? Because I don't have enough time, I have to figure out it ASAP.
Chris
Hi,Chris,
not
> Hi,
> 611079 [FINE]
> clean request is
> 611079 [FINE]
REQUEST=GetMap,
Looking for
Looking for
verifying
> configured strategy
service
reading
> request:
topp:yield
Feature
returning pg
> feature locking
handling
strategy is:
setting
> up map
Feature
returning pg
> feature locking
> 611250 [FINE]
> 611344 [FINE]
> calling renderer
Transform
[0.0,
attribute
> plant_key
attribute
> the_geom
processing 1
> stylers
processing style
> 0
processing rule
> 0
builder
3720834,
"oid",
'XDR'))
> 3655299))', 26914)
execute
3720834,
available
> connection.
> 623532 [FINE]
cache hit
type is:
> image/png
Service
> handled
> </ogc:Filter>
and Good
>> night.
Then
>>> we
going
>>> Chris
The
>>>> upper
db
>>>> table
table
>>>> and
your
>>>> > property names.
>>>> > Chris
>>>> >> Hi,
seems
>>>> not
>>>> >> work
>>>> works.
>>>> >> But
>>>> >> Rong.
document
>>>> >> <NamedLayer>
>>>> >> <UserStyle>
into
>>>> three
>>>> >> colors</Abstract>
>>>> >> <FeatureTypeStyle>
>>>> >> <Rule>
>>>> >> <ogc:LowerBoundary>
>>>> >> <ogc:UpperBoundary>
>>>> >> </ogc:Filter>
>>>> >> <PolygonSymbolizer>
>>>> >> <Fill>
and
>>>> >> fill-opacity -->
>>>> >> <CssParameter
>>>> >> </Fill>
>>>> >> </Rule>
>>>> >> <Rule>
>>>> >> </ogc:Filter>
>>>> >> <PolygonSymbolizer>
>>>> >> <Fill>
and
>>>> >> fill-opacity -->
>>>> >> <CssParameter
>>>> >> </Fill>
>>>> >> </Rule>
>>>> >> <Rule>
>>>> >> </ogc:Filter>
>>>> >> <PolygonSymbolizer>
>>>> >> <Fill>
and
>>>> >> fill-opacity -->
>>>> >> <CssParameter
>>>> >> </Fill>
>>>> >> </Rule>
>>>> >> <Rule>
>>>> >> <LineSymbolizer>
>>>> >> <Stroke/>
>>>> >> </LineSymbolizer>
>>>> >> </Rule>
>>>> >> </FeatureTypeStyle>
>>>> >> </UserStyle>
>>>> >> </NamedLayer>
>>>> >> Strategies
>>>> articles,
up
>>>> to
>>>> >> speed, fast.
Strategies
articles,
to
>>> speed, fast.
Strategies
articles,
to
Strategies
Strategies
Ok, let me get this straight. I may have some time to debug it for you,
which should go a bit faster than you doing it yourself.
1) A WFS Filter works fine against shapefile and postgis.
2) The same Filter embedded in a rule works fine against Shapefile
3) The same filter embedded in a rule does not work against PostGIS?
And what version of java are you working against? I ask because the sld
filter parser is weak (yes, we use different parsers, and are not proud
of it - it's because SLD people used DOM, we used SAX, and both use
filters), and can function differently depending on the DOM parser
being used. I'm positive SLD with Filters have worked in the past - we
had some problems against spatial filters, but those should be resolved
now as well.
Chris
debug
with
this
ASAP.
bug?
it's
> Chris
>> Hi,Chris,
is
>> not
sql
>> > Hi,
>> > 611079 [FINE]
>> > clean request is
>> > 611079 [FINE]
>> REQUEST=GetMap,
>> Looking for
>> Looking for
>> verifying
>> > configured strategy
Using
>> service
>> reading
>> > request:
>> topp:yield
>> Feature
>> returning pg
>> > feature locking
set 1
>> handling
>> strategy is:
>> setting
>> > up map
>> Feature
>> returning pg
>> > feature locking
>> > 611250 [FINE]
>> > 611344 [FINE]
>> > calling renderer
>> Transform
>> [0.0,
set 1
>> attribute
>> > plant_key
>> attribute
>> > the_geom
set 1
>> processing 1
>> > stylers
>> processing style
>> > 0
>> processing rule
>> > 0
sql
>> builder
>> 3720834,
SELECT
>> "oid",
>> 'XDR'))
((219638
>> > 3655299))', 26914)
>> execute
>> 3720834,
>> available
>> > connection.
>> > 623532 [FINE]
>> cache hit
mime
>> type is:
>> > image/png
>> Service
>> > handled
>> > </ogc:Filter>
>> and Good
>> >> night.
logs?
>> Then
>> >>> we
I'm
>> going
>> >>> Chris
work.
>> The
>> >>>> upper
the
>> db
>> >>>> table
db
>> table
>> >>>> and
for
>> your
>> >>>> > property names.
>> >>>> > Chris
>> >>>> >> Hi,
>> seems
>> >>>> not
>> >>>> >> work
It
>> >>>> works.
>> >>>> >> But
>> >>>> >> Rong.
>> document
>> >>>> >> <NamedLayer>
>> >>>> >> <UserStyle>
>> into
>> >>>> three
>> >>>> >> colors</Abstract>
>> >>>> >> <FeatureTypeStyle>
>> >>>> >> <Rule>
>> >>>> >> <ogc:Filter
>> >>>> >> <ogc:LowerBoundary>
>> >>>> >> <ogc:UpperBoundary>
>> >>>> >> </ogc:Filter>
>> >>>> >> <PolygonSymbolizer>
>> >>>> >> <Fill>
color)
>> and
>> >>>> >> fill-opacity -->
>> >>>> >> <CssParameter
>> >>>> >> </Fill>
>> >>>> >> </Rule>
>> >>>> >> <Rule>
>> >>>> >> <ogc:Filter
>> >>>> >> </ogc:Filter>
>> >>>> >> <PolygonSymbolizer>
>> >>>> >> <Fill>
color)
>> and
>> >>>> >> fill-opacity -->
>> >>>> >> <CssParameter
>> >>>> >> </Fill>
>> >>>> >> </Rule>
>> >>>> >> <Rule>
>> >>>> >> <ogc:Filter
>> >>>> >> </ogc:Filter>
>> >>>> >> <PolygonSymbolizer>
>> >>>> >> <Fill>
color)
>> and
>> >>>> >> fill-opacity -->
>> >>>> >> <CssParameter
>> >>>> >> </Fill>
>> >>>> >> </Rule>
>> >>>> >> <Rule>
>> >>>> >> <LineSymbolizer>
>> >>>> >> <Stroke/>
>> >>>> >> </LineSymbolizer>
>> >>>> >> </Rule>
>> >>>> >> </FeatureTypeStyle>
>> >>>> >> </UserStyle>
>> >>>> >> </NamedLayer>
Migration
>> >>>> >> Strategies
>> >>>> articles,
get
>> up
>> >>>> to
>> >>>> >> speed, fast.
>> Strategies
>> articles,
up
>> to
>> >>> speed, fast.
>> Strategies
>> articles,
up
>> to
>> >> speed, fast.
>> Strategies
articles,
to
>> Strategies
articles,
to
Strategies
> speed, fast.
Thank you very much for your help.I use JDK 1.5. Which version do you
suggest?
Best,
Rong
now as well.
Chris
debug
with
this
ASAP.
bug?
it's
> Chris
>> Hi,Chris,
is
>> not
sql
>> > Hi,
>> > 611079 [FINE]
>> > clean request is
>> > 611079 [FINE]
>> REQUEST=GetMap,
>> Looking for
>> Looking for
>> verifying
>> > configured strategy
Using
>> service
>> reading
>> > request:
>> topp:yield
>> Feature
>> returning pg
>> > feature locking
set 1
>> handling
>> strategy is:
>> setting
>> > up map
>> Feature
>> returning pg
>> > feature locking
>> > 611250 [FINE]
>> > 611344 [FINE]
>> > calling renderer
>> Transform
>> [0.0,
set 1
>> attribute
>> > plant_key
>> attribute
>> > the_geom
set 1
>> processing 1
>> > stylers
>> processing style
>> > 0
>> processing rule
>> > 0
sql
>> builder
>> 3720834,
SELECT
>> "oid",
>> 'XDR'))
((219638
>> > 3655299))', 26914)
>> execute
>> 3720834,
>> available
>> > connection.
>> > 623532 [FINE]
>> cache hit
mime
>> type is:
>> > image/png
>> Service
>> > handled
>> > </ogc:Filter>
>> and Good
>> >> night.
logs?
>> Then
>> >>> we
I'm
>> going
>> >>> Chris
work.
>> The
>> >>>> upper
the
>> db
>> >>>> table
db
>> table
>> >>>> and
for
>> your
>> >>>> > property names.
>> >>>> > Chris
>> >>>> >> Hi,
>> seems
>> >>>> not
>> >>>> >> work
It
>> >>>> works.
>> >>>> >> But
>> >>>> >> Rong.
>> document
>> >>>> >> <NamedLayer>
>> >>>> >> <UserStyle>
>> into
>> >>>> three
>> >>>> >> colors</Abstract>
>> >>>> >> <FeatureTypeStyle>
>> >>>> >> <Rule>
>> >>>> >> <ogc:Filter
>> >>>> >> <ogc:LowerBoundary>
>> >>>> >> <ogc:UpperBoundary>
>> >>>> >> </ogc:Filter>
>> >>>> >> <PolygonSymbolizer>
>> >>>> >> <Fill>
color)
>> and
>> >>>> >> fill-opacity -->
>> >>>> >> <CssParameter
>> >>>> >> </Fill>
>> >>>> >> </Rule>
>> >>>> >> <Rule>
>> >>>> >> <ogc:Filter
>> >>>> >> </ogc:Filter>
>> >>>> >> <PolygonSymbolizer>
>> >>>> >> <Fill>
color)
>> and
>> >>>> >> fill-opacity -->
>> >>>> >> <CssParameter
>> >>>> >> </Fill>
>> >>>> >> </Rule>
>> >>>> >> <Rule>
>> >>>> >> <ogc:Filter
>> >>>> >> </ogc:Filter>
>> >>>> >> <PolygonSymbolizer>
>> >>>> >> <Fill>
color)
>> and
>> >>>> >> fill-opacity -->
>> >>>> >> <CssParameter
>> >>>> >> </Fill>
>> >>>> >> </Rule>
>> >>>> >> <Rule>
>> >>>> >> <LineSymbolizer>
>> >>>> >> <Stroke/>
>> >>>> >> </LineSymbolizer>
>> >>>> >> </Rule>
>> >>>> >> </FeatureTypeStyle>
>> >>>> >> </UserStyle>
>> >>>> >> </NamedLayer>
Migration
>> >>>> >> Strategies
>> >>>> articles,
get
>> up
>> >>>> to
>> >>>> >> speed, fast.
>> Strategies
>> articles,
up
>> to
>> >>> speed, fast.
>> Strategies
>> articles,
up
>> to
>> >> speed, fast.
>> Strategies
articles,
to
>> Strategies
articles,
to
Strategies
> speed, fast.
Try 1.4
and can you confirm this:
And can you send a copy of your full SLD file?
suggest?
Best,
Rong
you,
PostGIS?
the sld
proud
- we
resolved
> now as well.
> Chris
I'll
to
>> debug
request
>> with
for
>> this
>> ASAP.
a
>> bug?
And
>> it's
>> PostGIS
>> > Chris
>> >> Hi,Chris,
sld
>> is
>> >> not
the
>> sql
>> >> > Hi,
>> >> > 611079 [FINE]
>> >> > clean request is
>> >> > 611079 [FINE]
>> >> REQUEST=GetMap,
>> >> Looking for
>> >> Looking for
>> >> verifying
>> >> > configured strategy
>> Using
>> >> service
>> >> reading
>> >> > request:
>> >> topp:yield
get
>> >> Feature
>> >> returning pg
>> >> > feature locking
>> set 1
>> >> > 611172 [FINE]
>> >> handling
>> >> > request:
>> >> strategy is:
>> >> > 611219 [FINE]
>> >> setting
>> >> > up map
get
>> >> Feature
>> >> returning pg
>> >> > feature locking
>> >> > 611250 [FINE]
>> >> > 611344 [FINE]
>> >> > calling renderer
Affine
>> >> Transform
>> >> [0.0,
>> set 1
added
>> >> attribute
>> >> > plant_key
added
>> >> attribute
>> >> > the_geom
>> set 1
>> >> processing 1
>> >> > stylers
>> >> processing style
>> >> > 0
>> >> processing rule
>> >> > 0
>> sql
>> >> builder
>> >> 3720834,
>> SELECT
>> >> "oid",
>> >> 'XDR'))
>> ((219638
219638
>> >> > 3655299))', 26914)
to
>> >> execute
WHERE
3655299,219638
>> >> 3720834,
Getting
>> >> available
>> >> > connection.
>> >> > 623532 [FINE]
Style
>> >> cache hit
>> mime
>> >> type is:
>> >> > image/png
>> >> Service
>> >> > handled
>> >> > </ogc:Filter>
Thanks
>> >> and Good
>> >> >> night.
>> logs?
>> >> Then
>> >> >>> we
(also
>> I'm
>> >> going
>> >> >>> Chris
>> work.
>> >> The
>> >> >>>> upper
>> the
>> >> db
>> >> >>>> table
for
>> db
>> >> table
>> >> >>>> and
cases
>> for
>> >> your
>> >> >>>> > property names.
>> >> >>>> > Chris
>> >> >>>> >> Hi,
table?I
>> >> seems
>> >> >>>> not
>> >> >>>> >> work
shapefile.
>> It
>> >> >>>> works.
>> >> >>>> >> But
>> >> >>>> >> Rong.
sld
>> >> document
>> >> >>>> >> <NamedLayer>
>> >> >>>> >> <UserStyle>
States
>> >> into
>> >> >>>> three
different
>> >> >>>> >> colors</Abstract>
>> >> >>>> >> <FeatureTypeStyle>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> <ogc:LowerBoundary>
>> >> >>>> >> <ogc:UpperBoundary>
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <LineSymbolizer>
>> >> >>>> >> <Stroke/>
>> >> >>>> >> </LineSymbolizer>
>> >> >>>> >> </Rule>
>> >> >>>> >> </FeatureTypeStyle>
>> >> >>>> >> </UserStyle>
>> >> >>>> >> </NamedLayer>
>> Migration
>> >> >>>> >> Strategies
straightforward
>> >> >>>> articles,
to
>> get
>> >> up
>> >> >>>> to
>> >> >>>> >> speed, fast.
>> >> Strategies
>> >> articles,
get
>> up
>> >> to
>> >> >>> speed, fast.
>> >> Strategies
>> >> articles,
get
>> up
>> >> to
>> >> >> speed, fast.
>> >> Strategies
>> articles,
up
>> to
>> >> > speed, fast.
>> >> Strategies
>> articles,
up
>> to
>> >> speed, fast.
>> Strategies
articles,
to
>> > speed, fast.
Ok, I'll try 1.4. Yes, I can confirm the liset below. I have test it with
different version.My fulll sld past as below. if it not ok for, PLS let me
know. I'll send you attachment.
  <NamedLayer>
    <Name>shp:yield</Name>
    <UserStyle>
    <FeatureTypeStyle>
                 <FeatureTypeName>feature</FeatureTypeName>
      <Rule>
        <Name>name</Name>
        <Title>title</Title>
        <Abstract>Abstract</Abstract>
        <ogc:Filter>
          <ogc:PropertyIsEqualTo>
        </ogc:PropertyIsEqualTo>
              </ogc:Filter>
        <PointSymbolizer>
          <Graphic>
          <Mark>
            <WellKnownName>star</WellKnownName>
            <Fill>
                <ogc:Literal>#0000FF</ogc:Literal>
              </CssParameter>
            </Fill>
              </Mark>
            <Opacity>
              <ogc:Literal>1.0</ogc:Literal>
            </Opacity>
            <Size>
              <ogc:Literal>20</ogc:Literal>
            </Size>
          </Graphic>
        </PointSymbolizer>
      </Rule>
    </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
Try 1.4
suggest?
Best,
Rong
you,
PostGIS?
the sld
proud
- we
resolved
> now as well.
> Chris
I'll
to
>> debug
request
>> with
for
>> this
>> ASAP.
a
>> bug?
And
>> it's
>> PostGIS
>> > Chris
>> >> Hi,Chris,
sld
>> is
>> >> not
the
>> sql
>> >> > Hi,
>> >> > 611079 [FINE]
>> >> > clean request is
>> >> > 611079 [FINE]
>> >> REQUEST=GetMap,
>> >> Looking for
>> >> Looking for
>> >> verifying
>> >> > configured strategy
>> Using
>> >> service
>> >> reading
>> >> > request:
>> >> topp:yield
get
>> >> Feature
>> >> returning pg
>> >> > feature locking
>> set 1
>> >> > 611172 [FINE]
>> >> handling
>> >> > request:
>> >> strategy is:
>> >> > 611219 [FINE]
>> >> setting
>> >> > up map
get
>> >> Feature
>> >> returning pg
>> >> > feature locking
>> >> > 611250 [FINE]
>> >> > 611344 [FINE]
>> >> > calling renderer
Affine
>> >> Transform
>> >> [0.0,
>> set 1
added
>> >> attribute
>> >> > plant_key
added
>> >> attribute
>> >> > the_geom
>> set 1
>> >> processing 1
>> >> > stylers
>> >> processing style
>> >> > 0
>> >> processing rule
>> >> > 0
>> sql
>> >> builder
>> >> 3720834,
>> SELECT
>> >> "oid",
>> >> 'XDR'))
>> ((219638
219638
>> >> > 3655299))', 26914)
to
>> >> execute
WHERE
3655299,219638
>> >> 3720834,
Getting
>> >> available
>> >> > connection.
>> >> > 623532 [FINE]
Style
>> >> cache hit
>> mime
>> >> type is:
>> >> > image/png
>> >> Service
>> >> > handled
>> >> > </ogc:Filter>
Thanks
>> >> and Good
>> >> >> night.
>> logs?
>> >> Then
>> >> >>> we
(also
>> I'm
>> >> going
>> >> >>> Chris
>> work.
>> >> The
>> >> >>>> upper
>> the
>> >> db
>> >> >>>> table
for
>> db
>> >> table
>> >> >>>> and
cases
>> for
>> >> your
>> >> >>>> > property names.
>> >> >>>> > Chris
>> >> >>>> >> Hi,
table?I
>> >> seems
>> >> >>>> not
>> >> >>>> >> work
shapefile.
>> It
>> >> >>>> works.
>> >> >>>> >> But
>> >> >>>> >> Rong.
sld
>> >> document
>> >> >>>> >> <NamedLayer>
>> >> >>>> >> <UserStyle>
States
>> >> into
>> >> >>>> three
different
>> >> >>>> >> colors</Abstract>
>> >> >>>> >> <FeatureTypeStyle>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> <ogc:LowerBoundary>
>> >> >>>> >> <ogc:UpperBoundary>
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <LineSymbolizer>
>> >> >>>> >> <Stroke/>
>> >> >>>> >> </LineSymbolizer>
>> >> >>>> >> </Rule>
>> >> >>>> >> </FeatureTypeStyle>
>> >> >>>> >> </UserStyle>
>> >> >>>> >> </NamedLayer>
>> Migration
>> >> >>>> >> Strategies
straightforward
>> >> >>>> articles,
to
>> get
>> >> up
>> >> >>>> to
>> >> >>>> >> speed, fast.
>> >> Strategies
>> >> articles,
get
>> up
>> >> to
>> >> >>> speed, fast.
>> >> Strategies
>> >> articles,
get
>> up
>> >> to
>> >> >> speed, fast.
>> >> Strategies
>> articles,
up
>> to
>> >> > speed, fast.
>> >> Strategies
>> articles,
up
>> to
>> >> speed, fast.
>> Strategies
articles,
to
>> > speed, fast.
Hi, Chris,
  As you said. It works OK with Java 1.4.2_08. It works for me now. Thank
you very much. Have agood weekend.
  Rong
===========================================================<?xml
  <NamedLayer>
    <UserStyle>
    <FeatureTypeStyle>
      <Rule>
        <Name>name</Name>
        <ogc:Filter>
              </ogc:Filter>
        <PointSymbolizer>
          <Graphic>
          <Mark>
            <Fill>
              </CssParameter>
            </Fill>
              </Mark>
            <Opacity>
            </Opacity>
            <Size>
            </Size>
          </Graphic>
        </PointSymbolizer>
      </Rule>
    </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
=============================================> Try 1.4
suggest?
Best,
Rong
you,
PostGIS?
the sld
proud
- we
resolved
> now as well.
> Chris
I'll
to
>> debug
request
>> with
for
>> this
>> ASAP.
a
>> bug?
And
>> it's
>> PostGIS
>> > Chris
>> >> Hi,Chris,
sld
>> is
>> >> not
the
>> sql
>> >> > Hi,
>> >> > 611079 [FINE]
>> >> > clean request is
>> >> > 611079 [FINE]
>> >> REQUEST=GetMap,
>> >> Looking for
>> >> Looking for
>> >> verifying
>> >> > configured strategy
>> Using
>> >> service
>> >> reading
>> >> > request:
>> >> topp:yield
get
>> >> Feature
>> >> returning pg
>> >> > feature locking
>> set 1
>> >> > 611172 [FINE]
>> >> handling
>> >> > request:
>> >> strategy is:
>> >> > 611219 [FINE]
>> >> setting
>> >> > up map
get
>> >> Feature
>> >> returning pg
>> >> > feature locking
>> >> > 611250 [FINE]
>> >> > 611344 [FINE]
>> >> > calling renderer
Affine
>> >> Transform
>> >> [0.0,
>> set 1
added
>> >> attribute
>> >> > plant_key
added
>> >> attribute
>> >> > the_geom
>> set 1
>> >> processing 1
>> >> > stylers
>> >> processing style
>> >> > 0
>> >> processing rule
>> >> > 0
>> sql
>> >> builder
>> >> 3720834,
>> SELECT
>> >> "oid",
>> >> 'XDR'))
>> ((219638
219638
>> >> > 3655299))', 26914)
to
>> >> execute
WHERE
3655299,219638
>> >> 3720834,
Getting
>> >> available
>> >> > connection.
>> >> > 623532 [FINE]
Style
>> >> cache hit
>> mime
>> >> type is:
>> >> > image/png
>> >> Service
>> >> > handled
>> >> > </ogc:Filter>
Thanks
>> >> and Good
>> >> >> night.
>> logs?
>> >> Then
>> >> >>> we
(also
>> I'm
>> >> going
>> >> >>> Chris
>> work.
>> >> The
>> >> >>>> upper
>> the
>> >> db
>> >> >>>> table
for
>> db
>> >> table
>> >> >>>> and
cases
>> for
>> >> your
>> >> >>>> > property names.
>> >> >>>> > Chris
>> >> >>>> >> Hi,
table?I
>> >> seems
>> >> >>>> not
>> >> >>>> >> work
shapefile.
>> It
>> >> >>>> works.
>> >> >>>> >> But
>> >> >>>> >> Rong.
sld
>> >> document
>> >> >>>> >> <NamedLayer>
>> >> >>>> >> <UserStyle>
States
>> >> into
>> >> >>>> three
different
>> >> >>>> >> colors</Abstract>
>> >> >>>> >> <FeatureTypeStyle>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> <ogc:LowerBoundary>
>> >> >>>> >> <ogc:UpperBoundary>
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <ogc:Filter
>> >> >>>> >> </ogc:Filter>
>> >> >>>> >> <PolygonSymbolizer>
>> >> >>>> >> <Fill>
>> color)
>> >> and
>> >> >>>> >> fill-opacity -->
>> >> >>>> >> <CssParameter
>> >> >>>> >> </Fill>
>> >> >>>> >> </Rule>
>> >> >>>> >> <Rule>
>> >> >>>> >> <LineSymbolizer>
>> >> >>>> >> <Stroke/>
>> >> >>>> >> </LineSymbolizer>
>> >> >>>> >> </Rule>
>> >> >>>> >> </FeatureTypeStyle>
>> >> >>>> >> </UserStyle>
>> >> >>>> >> </NamedLayer>
>> Migration
>> >> >>>> >> Strategies
straightforward
>> >> >>>> articles,
to
>> get
>> >> up
>> >> >>>> to
>> >> >>>> >> speed, fast.
>> >> Strategies
>> >> articles,
get
>> up
>> >> to
>> >> >>> speed, fast.
>> >> Strategies
>> >> articles,
get
>> up
>> >> to
>> >> >> speed, fast.
>> >> Strategies
>> articles,
up
>> to
>> >> > speed, fast.
>> >> Strategies
>> articles,
up
>> to
>> >> speed, fast.
>> Strategies
articles,
to
>> > speed, fast.
I have created a Bug report followed the link you give to me.If you need
any detail information. PLS let me know.
Thanks
Rong.
Oh cool, my procrastination paid off. I was going to look into it
today, and then was planning on it tomorrow. God I hate that parser,
and the fact that we use different parsers for 1.4 and 1.5. Will you
report this as a bug? That it doesn't work with 1.5? And include the
sld file, and that it works with shapefiles and not postgis (which I
find extremely odd, but so it goes).
glad it's working for you now though.
Chris
Hi, Chris,
Thank
  Rong
it with
let me
> <NamedLayer>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <Name>name</Name>
> <ogc:Filter>
> </ogc:Filter>
> <PointSymbolizer>
> <Graphic>
> <Mark>
> <Fill>
> </CssParameter>
> </Fill>
> </Mark>
> <Opacity>
> </Opacity>
> <Size>
> </Size>
> </Graphic>
> </PointSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
Shapefile
PostGIS?
you
>>> suggest?
>>> Best,
>>> Rong
for
>>> you,
Shapefile
>>> PostGIS?
because
>>> the sld
not
>>> proud
use
parser
past
>>> - we
>>> resolved
>>> > now as well.
>>> > Chris
>>> I'll
try
>>> to
>>> >> debug
>>> request
>>> >> with
way
>>> for
>>> >> this
out it
>>> >> ASAP.
it as
>>> a
>>> >> bug?
>>> And
>>> >> it's
with
>>> >> PostGIS
>>> >> > Chris
>>> >> >> Hi,Chris,
with
>>> sld
>>> >> is
>>> >> >> not
for
>>> the
>>> >> sql
>>> >> >> > Hi,
>>> >> >> > 611079 [FINE]
>>> >> >> > clean request is
>>> >> >> > 611079 [FINE]
>>> >> >> REQUEST=GetMap,
>>> >> >> > 611094 [INFO]
>>> >> >> Looking for
>>> >> >> > 611110 [INFO]
>>> >> >> Looking for
>>> >> >> > 611110 [FINE]
>>> >> >> verifying
>>> >> >> > configured strategy
>>> >> >> > 611125 [INFO]
>>> >> Using
>>> >> >> service
>>> >> >> > 611125 [FINE]
>>> >> >> reading
>>> >> >> > request:
type
>>> >> >> topp:yield
>>> get
>>> >> >> Feature
>>> >> >> returning pg
>>> >> >> > feature locking
fts
>>> >> set 1
>>> >> >> > 611172 [FINE]
>>> >> >> > 611172 [INFO]
>>> >> >> handling
>>> >> >> > request:
>>> >> >> > 611188 [FINE]
>>> >> >> strategy is:
>>> >> >> > 611219 [FINE]
>>> >> >> setting
>>> >> >> > up map
>>> get
>>> >> >> Feature
>>> >> >> returning pg
>>> >> >> > feature locking
>>> >> >> > 611250 [FINE]
>>> >> >> > 611344 [FINE]
>>> >> >> > calling renderer
>>> Affine
>>> >> >> Transform
>>> >> >> [0.0,
fts
>>> >> set 1
>>> added
>>> >> >> attribute
>>> >> >> > plant_key
>>> added
>>> >> >> attribute
>>> >> >> > the_geom
fts
>>> >> set 1
>>> >> >> processing 1
>>> >> >> > stylers
>>> >> >> processing style
>>> >> >> > 0
>>> >> >> processing rule
>>> >> >> > 0
calling
>>> >> sql
>>> >> >> builder
219638
>>> >> >> 3720834,
is
>>> >> SELECT
>>> >> >> "oid",
>>> >> >> 'XDR'))
>>> >> ((219638
>>> 219638
>>> >> >> > 3655299))', 26914)
About
>>> to
>>> >> >> execute
>>> WHERE
>>> 3655299,219638
>>> >> >> 3720834,
>>> Getting
>>> >> >> available
>>> >> >> > connection.
>>> >> >> > 623532 [FINE]
>>> Style
>>> >> >> cache hit
>>> >> >> > 623563 [FINE]
>>> >> mime
>>> >> >> type is:
>>> >> >> > image/png
>>> >> >> > 628017 [INFO]
>>> >> >> Service
>>> >> >> > handled
>>> >> >> > </ogc:Filter>
>>> Thanks
>>> >> >> and Good
>>> >> >> >> night.
the
>>> >> logs?
>>> >> >> Then
>>> >> >> >>> we
>>> (also
>>> >> I'm
>>> >> >> going
awhile).
>>> >> >> >>> Chris
doesn't
>>> >> work.
>>> >> >> The
>>> >> >> >>>> upper
for
>>> >> the
>>> >> >> db
>>> >> >> >>>> table
case
>>> for
>>> >> db
>>> >> >> table
>>> >> >> >>>> and
>>> cases
>>> >> for
>>> >> >> your
>>> >> >> >>>> > property names.
>>> >> >> >>>> > Chris
>>> >> >> >>>> >> Hi,
>>> table?I
>>> >> >> seems
>>> >> >> >>>> not
>>> >> >> >>>> >> work
>>> shapefile.
>>> >> It
>>> >> >> >>>> works.
>>> >> >> >>>> >> But
me?
>>> >> >> >>>> >> Rong.
an
>>> sld
>>> >> >> document
>>> >> >> >>>> >> <NamedLayer>
>>> >> >> >>>> >> <UserStyle>
abstracts
>>> States
>>> >> >> into
>>> >> >> >>>> three
>>> different
>>> >> >> >>>> >> colors</Abstract>
>>> >> >> >>>> >> <FeatureTypeStyle>
>>> >> >> >>>> >> <Rule>
too
>>> >> >> >>>> >> <ogc:Filter
>>> >> >> >>>> >> <ogc:LowerBoundary>
>>> >> >> >>>> >> <ogc:UpperBoundary>
>>> >> >> >>>> >> </ogc:Filter>
>>> >> >> >>>> >> <PolygonSymbolizer>
>>> >> >> >>>> >> <Fill>
(the
>>> >> color)
>>> >> >> and
>>> >> >> >>>> >> fill-opacity -->
>>> >> >> >>>> >> <CssParameter
>>> >> >> >>>> >> </Fill>
>>> >> >> >>>> >> </Rule>
>>> >> >> >>>> >> <Rule>
too
>>> >> >> >>>> >> <ogc:Filter
>>> >> >> >>>> >> </ogc:Filter>
>>> >> >> >>>> >> <PolygonSymbolizer>
>>> >> >> >>>> >> <Fill>
(the
>>> >> color)
>>> >> >> and
>>> >> >> >>>> >> fill-opacity -->
>>> >> >> >>>> >> <CssParameter
>>> >> >> >>>> >> </Fill>
>>> >> >> >>>> >> </Rule>
>>> >> >> >>>> >> <Rule>
too
>>> >> >> >>>> >> <ogc:Filter
>>> >> >> >>>> >> </ogc:Filter>
>>> >> >> >>>> >> <PolygonSymbolizer>
>>> >> >> >>>> >> <Fill>
(the
>>> >> color)
>>> >> >> and
>>> >> >> >>>> >> fill-opacity -->
>>> >> >> >>>> >> <CssParameter
>>> >> >> >>>> >> </Fill>
>>> >> >> >>>> >> </Rule>
>>> >> >> >>>> >> <Rule>
>>> >> >> >>>> >> <LineSymbolizer>
>>> >> >> >>>> >> <Stroke/>
>>> >> >> >>>> >> </LineSymbolizer>
>>> >> >> >>>> >> </Rule>
>>> >> >> >>>> >> </FeatureTypeStyle>
>>> >> >> >>>> >> </UserStyle>
>>> >> >> >>>> >> </NamedLayer>
>>> >> Migration
>>> >> >> >>>> >> Strategies
>>> straightforward
>>> >> >> >>>> articles,
need
>>> to
>>> >> get
>>> >> >> up
>>> >> >> >>>> to
>>> >> >> >>>> >> speed, fast.
Migration
>>> >> >> Strategies
straightforward
>>> >> >> articles,
to
>>> get
>>> >> up
>>> >> >> to
>>> >> >> >>> speed, fast.
Migration
>>> >> >> Strategies
straightforward
>>> >> >> articles,
to
>>> get
>>> >> up
>>> >> >> to
>>> >> >> >> speed, fast.
Migration
>>> >> >> Strategies
>>> >> articles,
get
>>> up
>>> >> to
>>> >> >> > speed, fast.
>>> >> >> Strategies
>>> >> articles,
get
>>> up
>>> >> to
>>> >> >> speed, fast.
>>> >> Strategies
>>> articles,
get up
>>> to
>>> >> > speed, fast.
Strategies
Hi,Chris,
  I have a question about the unique sequence hangling. Here is my case, I
need a unique sequence key for one table A as a promary key. Other two
tables(B,C) will refere this as a foreign key. My java program need add
records to the first table(A) and update the foreign key into the other
two tables(B,c). All this should happen in one transaction in roder to
maintain the data consistence. I know I can create a sequence(CREATE
SEQUENCE mykey) and use nextval('mykey') to get the next sequence key. I
can do this via my own JDBC connection. But my question is: how can I
get this via geotools DataStore? Or How can I get the JDBC connection
used by the Geotools DataStore? I did some research from the geotolls
source and I didn't find any useful examples. Do you have any
suggestions?
  Rong.
Hi,Chris,
case, I
two
add
other
to
key. I
suggestions?
So right now there's no way to get the JDBC connection directly from the
datastore, as the getConnection method is protected. You're the second
user to ask about getting the connection in the past couple weeks
though, so I'm wondering if maybe we should allow access in some way.
The thing is we have code in place to deal with transactions, and I'm
not sure we want to open that up to the public api. Basically a
getConnection takes a 'Transaction' object, which will hold on to
single jdbc connection to be used for more than one operation to be
done on a single commit. Of course, this seems to be exactly the type
of behavior you want. It also manages the connection pool stuff. What
do geotools people think? Would it be bad to open up this method to
public consumption? Let users who know to make use of JDBC get into
the internals of their datastore?
Another option would be to just extend the appropriate datastore, make a
customized version for your needs. That would probably be the cleaner
way to handle it, geared towards your use case. You can make use of
the getConnection methods of JDBCDataStore, and adjust the transaction
methods to take the action that you want.
best regards,
Chris
  Rong.
Strategies
