[Geoserver-devel] Fine Grained WFS Control
Chris Holmes wrote:
I made a jira task for this geos-36. The enabled flag doesn't do anything, so I'll fix it. Sean also chimed in with thoughts on authentication, which might be a really good thing to look into for your project. I'm actually kinda surprised it wasn't part of the requirements.
Actually it is there in the work flow diagrams - you need to "login" in order to mess with the configuration :slight_smile:
Actually every mock ui has a logout link on the top
What I was not doing was a general change the getCapabilities document based on what the user has logged in as solution. Although when that comes down the the pipes it may conflict with whatever I do for allowing configuration.
Jody
