Justin,
we ran into a few build failures after your GWC VERSION.txt changes (IRC log attached).
I committed 8e51ce269eaab07cfa04b700e2dcb909133675ed to master: "Fixed broken ant groupId, which appears to have changed from ant to org.apache.ant for 1.8.x. This was causing build failures for anyone without ant:ant:jar:1.8.2 in their local repo. Also changed ant and ant-launcher version to 1.8.4."
Apologies in advance for the cross-module commit, and doubly so if I have b0rked anything.
On the plus side, I can confirm that the GWC version info now appears in VERSION.txt, so your changes work. Thanks!
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
(attachments)
geoserver.2012-07-31.log (11.3 KB)
Cool. Thanks Ben!
On Tue, Jul 31, 2012 at 1:52 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Justin,
I committed 8e51ce269eaab07cfa04b700e2dcb909133675ed to master: “Fixed broken ant groupId, which appears to have changed from ant to org.apache.ant for 1.8.x. This was causing build failures for anyone without ant:ant:jar:1.8.2 in their local repo. Also changed ant and ant-launcher version to 1.8.4.”
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
OpenGeo - http://opengeo.org
