Currently the python community module is disabled. The reason being that it requires some sources from the geoscript-py git repository. Originally I simply added this as as svn external but unfortunately github svn support is shoty at best, and fails often. My next shot at a solution would be to simply use git directly to check out the sources, executed via an ant script. I have used approach on other projects and it works well.
The downside then becomes that git would be required on the path to build the module… which probably is not a problem for most developers who are now using git and probably not a problem since most developers don’t build that community module. But I was wanted to check with folks regardless. If people think it will be too much headache I can try for another solution.
Thanks!
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
