Justin,
short version: I support both (a) and (b).
It took me years to figure out how fixversion is used; we should explain what it is for and promulgate this information. One problem is that issue reporters set fixversion as an appeal to maintainers and this may not be corrected.
From my understanding, we use fixversion for two distinct purposes:
(1) Identifying release blockers (your previous example of open issues with priority>=critical with fixversion set to the upcoming release). This is the aspirational interpretation ("should be fixed for version").
(2) Generating release changelog. This is the historical record interpretation ("was fixed for version").
In my view, it is the responsibility of whoever is resolving or closing an issue to set fixversion for the branch and upcoming release. Some developers might not know this. Some developers might not realise that it is different from affects version. Some may be reluctant to change it if set by a senior.
It would be easier if a kind Jira admin would arrange for the next trunk and stable release versions to be near the top of the list.
Some fixversions are mistakes. It is quite easy to set when affects-version is meant.
Kind regards,
Ben.
On 22/05/12 11:28, Justin Deoliveira wrote:
Hey folks,
As I wrap up the 2.2-beta2 release i am looking at the changelog for 2.2-beta2 and something is a miss.
http://jira.codehaus.org/secure/ReleaseNote.jspa?projectId=10311&version=18437
Just over a dozen issues... doesn't sound right and indeed it is not. What's happening is that issues resolved are not being marked with a fixVersion or marked with a fixVersion on 2.1.x only even though the fix occurs on trunk as well.
First question. Is this intentional? If the answer is no second question is can we make it jira policy to (a) always mark the fixVersion and (b) mark it to reflect all branches a fix was done on?
Thanks.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
