[Geoserver-devel] For the installation of GEOS
Hi,everyone,
I try to install PostGIS database,but the configuration of PostGIS in Geoserver recommends to install GEOS before that. I downloaded GEOS 2.2.1 but I do not find any installation files like setup.exe or something like that. How can I install GEOS? Many thanks!
Cathy
_________________________________________________________________
ÓëÁª»úµÄÅóÓѽøÐн»Á÷£¬ÇëʹÓà MSN Messenger: http://messenger.msn.com/cn
Cathy,
If you installed postgis from a windows installer, then GEOS was included by default, so no need to do anything else.
P
On Jan 30, 2006, at 2:13 AM, gwx cathy wrote:
Hi,everyone,
Cathy
与联机的朋友进行交流,请使用 MSN Messenger: http://messenger.msn.com/cn
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&dat=121642
Geoserver-devel mailing list
Hi, everyone,
I installed PostgreSQL 8.1 and PostGIS 1.1.1. Now I try to make clear how to connect Geoserver with PostGIS database. According to the instructure of the PostGIS configuration in GeoServer. I can not find right command window (psql tool) to input the commands.
I installed Geoserver and PostGIS in my labtop, the former providing Web Feature Service and the latter providing data service. What protocol is used for the communication between the two services?
best regards,
Cathy
To: gwx cathy <gwx_cathy@anonymised.com>
CC: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] For the installation of GEOS
Date: Mon, 30 Jan 2006 09:50:01 -0800
Cathy,
P
Hi,everyone,
Cathy
与联机的朋友进行交流,请使用 MSN Messenger: http:// messenger.msn.com/cn
http://sel.as-us.falkag.net/sel? cmd=lnk&kid=103432&bid=230486&dat=121642
On 2/1/06, gwx cathy <gwx_cathy@...21...> wrote:
Hi, everyone,
Are you interested in the protocol (TCP/IP I guess?), or what is used
by Geoserver to connect to a Postgis database?
I believe the necessary drivers for making a database connection are
already included in the Geoserver release as a jar archive in the
WEB-INF/lib directory (gt2-postgis.jar).
Alex
