[Geoserver-devel] forwarding geotools logging
Is there a convenient way to have geotools log messages forwarded to the geoserver console? I am building from trunk and starting Geoserver in Jetty from eclipse. I tried the tip from the javadocs of adding a line to Start.java
        Logging.GEOTOOLS.setLoggerFactory("org.geotools.util.logging.CommonsLoggerFactory");
but I don't notice any geotools messages showing up in my console or log file.
Thanks, Tara
Tara Athan
Owner, Athan Ecological Reconciliation Services
tara_athan at alt2is.com
707-272-2115 (cell, preferred)
707-485-1198 (office)
249 W. Gobbi St. #A
Ukiah, CA 95482
While I have never tried this personally it seems that there is a way to do this via system property. Setting:
-DGT2_LOGGING_REDIRECTION=CommonsLogging
If you look at the LoggingStartupContextListener class in the main module you will see how it used.
-Justin
On Sun, Sep 12, 2010 at 7:39 PM, Tara Athan <taraathan@anonymised.com> wrote:
to Start.java
Logging.GEOTOOLS.setLoggerFactory(“org.geotools.util.logging.CommonsLoggerFactory”);
but I don’t notice any geotools messages showing up in my console or log
file.
Thanks, Tara
Tara Athan
249 W. Gobbi St. #A
Ukiah, CA 95482
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
