I was checking Jenkins to have a feeler about a Travis Java 11 failure (wanted to see if it
was happening on Jenkins too) and found all builds were stuck since August 1st:
Checking some builds, they seemed not to have been started at all…
The new builds do not seem to be doing any better, also stuck at the beginning:
Hmm… wondering if the builders are gone? Or maybe the disk space is depleted?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Not a disk space issue (and this is not likely to be an issue anytime soon) - only using 87G of 250G.
I restarted (and updated) the Jenkins service, and things seem to be running again. I’m still not sure what caused the initial failure, but I’ll keep an eye on it for a bit. Might have been some sort of deadlock or memory issue?
That looks like a standard maven error, nothing to do with Jenkins. Either the repository is offline or there is an error in the GeoServer POM file. Travis CI is showing the same failure: https://travis-ci.org/github/geoserver/geoserver
GeoTools seems to be building fine against the same repo, so most likely an error in the GeoServer POM.
