[Geoserver-devel] FreefsLog Exception
Hi, I just checked out the latest trunk.
Path: .
URL: svn://svn.codehaus.org/geoserver/scm/trunk/geoserver
Repository UUID: ef1d6e69-97e5-0310-af46-8a06194da32a
Revision: 4011
Node Kind: directory
Schedule: normal
Last Changed Author: jdeolive
Last Changed Rev: 4011
Last Changed Date: 2005-12-02 16:08:34 -0500 (Fri, 02 Dec 2005)
Properties Last Updated: 2005-12-03 13:09:37 -0500 (Sat, 03 Dec 2005)
1) Import project into Eclipse
2) Ant -> Debug From IDE
3) Switch to Debug Perspective
4) Debug org.mortbay.start.Main
I get the following exception, and GeoServer terminates:
13:38:28.250 EVENT Stopped org.mortbay.jetty.Server@anonymised.com
java.lang.IllegalAccessException: Class
org.vfny.geoserver.servlets.FreefsLog can not access a member of class
org.geotools.data.arcsde.ConnectionPoolFactory with modifiers "public
static synchronized"
  at sun.reflect.Reflection.ensureMemberAccess(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.vfny.geoserver.servlets.FreefsLog.destroy(FreefsLog.java:96)
  at org.mortbay.jetty.servlet.ServletHolder.stop(ServletHolder.java:244)
  at org.mortbay.jetty.servlet.ServletHandler.stop(ServletHandler.java:470)
  at org.mortbay.jetty.servlet.WebApplicationHandler.stop(WebApplicationHandler.java:163)
  at org.mortbay.http.HttpContext.stop(HttpContext.java:1978)
  at org.mortbay.jetty.servlet.ServletHttpContext.stop(ServletHttpContext.java:145)
  at org.mortbay.jetty.servlet.WebApplicationContext.stop(WebApplicationContext.java:504)
  at org.mortbay.http.HttpContext.stop(HttpContext.java:1949)
  at org.mortbay.http.HttpServer.stop(HttpServer.java:732)
  at org.mortbay.http.HttpServer.stop(HttpServer.java:700)
  at org.mortbay.jetty.Server$1.run(Server.java:455)
Yes I get this exception as well. It doesn't really effect anything unless you are using the ArcSDE datastore. This is probably one for geotools as the logger cant reflectivley call the appropriate method with its current modifiers.
I will make a jira task to look into this one.
Justin
Path: .
Revision: 4011
Schedule: normal
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
