Well we met with them but did not get far, hoping they will call back at some point.
Jody
I had a look a FROGS, but I thought, that their geoserver integration is
just at an early design stage. However, we do have the WPS
implementation already running compliant to the current spec. So I
think, it is valid to get this extension started, correct? Otherwise
please point me to a link, about FROGS and their geoserver integration.Best regards
Theodor
-----Original Message-----
From: Jody Garnett [mailto:jgarnett@anonymised.com] Sent: Thursday, August 31, 2006 5:49 PM
To: Theodor Foerster
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] WPS plugin for geoserverDude since you are on a timeline, the FROGS project does have a WPS
stack already in place we tried working with them, but they were shy on
email. Why not grab there code and see if you can get done quicker.
(at the very least they probably have something that parses a WPS
request).
Jody
Jody, thanks for your comments. I just went through them and saw a lot
of new decisions appearing. I think I will try to set up the WPSDataStore for each WPS instance. Thus one WPSDataStore has multiple
FeatureTypes (i.e. processes). By now that s only a prototype... I will try to figure out the Geotools OWS capabilties later, if the prototype is suffient.To give some more details about the context of my planned implementation. I will trigger mostly the WPS, provided by 52north at incubator52n.de/twiki/bin/view/Processing/52nWebProcessingService .
Finally I will link there any implementation code of the extension, if
there are no problems with any licensing...I may get back to one of your comments in advance... Thanks again!
Theodor
Sent: Thursday, August 31, 2006 5:19 PM
Subject: Re: [Geoserver-devel] WPS plugin for geoserverThat is a lot of questions, let me try:
I just started to extend geoserver (v.1.3.0) for WPS support. The idea
is to serve geoprocesses through geoserver, in particular through the
WMS (WFS could be a future task). I am writing the WPS extension as a
read-only DataStore in geoserver.
That is a interesting choice, WPS is a protocol (not a source of data)
- I am not sure I understand this design decision?
By now, I can create WPS instances in geoserver as DataStores, but what do I have to do to create actual FeatureStores?
You need to configure a GeoTools FeatureTypeInfo, you can do this using the user interface (or by hacking and XML in your own conf
directory).
You may also try out Justin's new GeoTools catalog backed GeoServer available in the community module (which I am trying to figure out now)
- the api for programmers is a lot more direct.However in my limited understanding a Web Processing Service, is supposed to accept an OWS Request that includes a WFS request to a Web
Feature Service, the WPS would fetch features, process them, and return the result. (I do hope that is correct).You can find an example HelloWorld Open Web Service as part of the GeoServer 1.4 documentation.
Or how do I get the processed results out to geoserver?
If your processed results are set up as part of your geoserver configuration (either the xml files, or by hand using the config ui) they will be published for other applications. Alternatively the WPS specification tells you an different protocol (ie not Web Feature
Server) by which you can do this.
What is the role of the namespaces?
namespace is the namespace for the resulting GML content.
How can I pass dynamic parameters of the WMS request to the
DataStore?
The dynamic paramters from the WMS request are limited to a bounding box, it will get reprojected into some kind of spatial query based on a Polygon, the other dynamic parameters are based on the Style Layer Descriptor specificaiton and are handled by the rendering process. (as
an example they define a series of explicit queries against your DataStore, sometimes only requesting a geometry attribute for
display).
I will match each WPS-process with a FeatureType. However that s perhaps not the best way, but straight-forward. Additionally I have to
deal with a little time constraint. The stuff has to work until end of
next week
Fun, so does your WPS need to be in agreement with the specification? If so you should start defining your own community module to handle WPS requests, capturing each request in a DataStore would be tough, you could (when you define your process) accept DataStoreFactorySPI parameters to handle the "dynamic" paramters include in your specific request.
You would be making these datastores up per each request though, so you would really need to understand Justins new catalog. Or you could just make them, use them to generate some GML, and then throw them away again.
I am looking forward to any comments concerning some design issues, but also how to solve the above mentioned problems.
Sounds to me like you are making up a new service:
1. define a module (as per examples in the community space) 2. when handling your request produce a Map of the dynamic parameters 3. use the Map of parameters to create a new "DataStore"
4. use that datastore to generate some GML (using the existing geoserver codebase as an example) 5. throw away the datastore after
use.
Jody
TheodorITC, Enschede
Department of Geo Information Processing PO. Box 6 7500 AA Enschede the Netherlands---------------------------------------------------------------------
--- Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121
6
42 _______________________________________________
Geoserver-devel mailing list
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=1216
