+1
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Kevin Smith [mailto:smithkm@…3859…]
Lähetetty: 4. kesäkuuta 2018 20:23
Vastaanottaja: geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Full reformat of GeoServer source code June 9th-10th?
+1
On 2018-06-03 06:05 PM, Ben Caradoc-Davies wrote:
+1. Please proceed. Thank you for implementing the reformat. We will
ask submitters to revise any conflicting PRs. Everyone has been warned
well in advance.Kind regards,
Ben.On 02/06/18 19:30, Andrea Aime wrote:
looks like the pull requests against GeoServer are not taking any pause.
On the bright side, right now there are only those unaffected by the
reformat (i18n) and a few newer ones.Can we agree to try to close the existing ones, and not to leave new
open ones, for the next weekend, June 9th-10th? And those that are
left there, will just have to put up with it and amend conflicts?Cheers
Andrea==
http://goo.gl/it488V for more information. == Ing. Andrea Aime
@geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A
55054 Massarosa (LU) phone:
+39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con
riferimento alla normativa sul trattamento dei dati personali (Reg.
UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
si precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se
il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
altra operazione è illecita. Le sarei comunque grato se potesse
darmene notizia. This email is intended only for the person or entity
to which it is addressed and may contain information that is
privileged, confidential or otherwise protected from disclosure. We
remind that - as provided by European Regulation 2016/679 “GDPR” -
copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If
you have received this email by mistake, please notify us immediately
by telephone or e-mail.*---------------------------------------------------------------------
---------Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Kevin Michael Smith
<smithkm@...3859...>
