[Geoserver-devel] Fully automating CITE tests?
looking someone struggingling for the n-th time trying to
make a release makes me really wonder about the viability
of the current release process.
In short, imho, the process as-is can be carried on only by a core
developer, for the simple reason that running cite tests can
uncover issues, and those in turn can be fixed only by
someone that knows GS/GT well.
And oh, provided you manage to put togheter the necessary black
magic to make the cite tests to work.
I consider making GS releases a sort of art (and a test of anyone
patience).
Having CITE tests out of the release process would be a great
step in simplifying the process.
To do that we have to either give up the confirmation that we're
still CITE compliant, or we have to consider CITE as a daily
activity, something that runs automatically just as our normal
build.
Do you think it's possible to fully automate the process?
The bits needed are:
a) setting up databases: check, it's something that can be done,
    give the build process a configuration of where the db is
    and a script that can clean up and rebuild the db and
    we're in business
b) starting up and shutting down GeoServer: check, the Start
    utility class could be used as a starting point for something
    that starts a GeoServer with a specific configuration,
    and eventually shuts it down
c) starting up the CITE tests with a specific configuration:
    uh, dunno... maybe? This is where I see various issues.
Issues with teamengine:
- to run as part of a maven build we'd need to package up
   and put on repositories the engine and the test suite.
   This is redistribution. Is that something we can do?
   If we cannot, I guess we can still resort to some form
   of private sharing, marking those jars as "provided"
   and giving to a selected number of people the files along
   with the instructions to install them in their maven
   repositories.
- the teamengine already has command line utilities to start
   a specific test suite, but I see no way to specify the
   parameters, which are usually asked for in an interactive window.
   I see no easy way to state the test parameters manually.
   This looks like a roadblock
- Once the suite is run we need to collect the results and
   declare victory or failure.
   It's something that can be done by looking into the
   logs, and seems a bit painful, but doable
If we can go past the above issues I believe we could
roll a set of maven modules, each designed to have
a specific set of dependencies (think about the need
to exclude WCS 1.1 in WCS 1.0 tests), each performing
a custom setup (db, files, whatever) and running
a specific test suite.
Basically a module to be built for each of the
CITE tests that we want to run.
And then imagine Hudson running that every single night.
Imagine also that you get a report of failures, and you
can run one of the above builds specifying the exact
test you want to re-run for debug purposes.
May not seem much, but to me, compared to what we have
today, feels like Nirvana.
Andrea Aime
OpenGeo - http://opengeo.org
    repositories.
I believe the teamengine is open source. So I think we should be able to redistribute, and also make additions to specify parameters. We could offer these as patches, or in worst case work with a forked version. I'll ask OGC people.
Chris
    repositories.
Yeah, the engine is open source. The test suites themselves are kept in
a separate repo that you can access only if you have been authorized
to, so those might be under a different license.
I looked into the test suite sources and could not find any license
header though, so... dunno. Hopefully OGC people will tell us
how we have to play this one.
Andrea Aime
+a lot.
As someone who wore the Release Manager hat a few times, this was essentially my experience. The CITE tests as part of the release process was the most inefficient part, since I could do nothing about any test failures, so I had to play whisper-down-the-lane with the core devs. This back and forth could stretch out interminably.
Automating CITE tests would make it much easier to push the rock over the hill. I might even want to volunteer to release again!
Mike Pumphrey
On 5/14/2010 3:31 AM, Andrea Aime wrote:
patience).
build.
     we're in business
    repositories.
I took a run at doing this a while back with some simple patches to the engine sources and met with limited success just running into too many issues with random failures.
Quite honestly if I had to look at solving this problem it might be to come up with a new and much simpler engine not built on xslt. The way the tests are structured makes it easy to pull out the relevant information:
(a) the xml for the requests the engine makes to teh server for a given test case
(b) the assertions the engine makes on the server responses
Some scripts could pull out all the information into a text file or something. That coupled with a light java testing framework with some utility methods for making this style of assertions could go a long way.
Anyways, crazy idea and probably a pipe dream i know... but it's one that has stemmed from hours of debugging xslt when something in a test fails. And if it were just simple xslt that would be fine. But its xslt that generated xslt that generates xml which makes my head hurt.
2c.
On 10-05-14 1:31 AM, Andrea Aime wrote:
patience).
build.
     we're in business
    repositories.
Justin Deoliveira
Andrea and Jody worked on some content validation services against WFS
- this is OS - "duckhawk" I think they called it.
I wonder how far that is away from being able to execute the CITE tests?
As you pointed out, the good thing about CITE is the tests are
separated and formalised, and not hidden in code.
Maybe there is a middle ground - run automated tests on build using
duckhawk and only go to formal CITE on the release cycle - because its
going to be hard to get our automated tests confirmed as valid CITE
compliance tests (I guess) in the short term.
Rob
On Sat, May 15, 2010 at 1:16 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
test case
2c.
patience).
build.
we're in business
repositories.
Justin Deoliveira
Geoserver-devel mailing list
I claim innocence - I think it was Andrea and Jim. At least it was before my time :slight_smile:
I think that the "only go to CITE tests during the release cycle" is the problem - we want help with the release cycle and CITE tests being hidden are standing in the way.
As for the other point; we could support the person running the cite tests on IRC / Skype / Email as they make the release and find trouble.
Jody
Rob
test case
2c.
patience).
build.
     we're in business
    repositories.
Justin Deoliveira
sounds like Justin is doing some heroic work with team engine - and I
guess we can do official tests in the nightly builds.
On Sat, May 15, 2010 at 9:37 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
Rob
test case
2c.
patience).
build.
we're in business
repositories.
Justin Deoliveira
I have emailed Raj Singh (OGC Interoperability Programs Director) to see if he has made any progress opening up SVN access to the CITE tests. We discussed this at FOSS4G, but I have not heard from him since October 2009. I coped my email to this list, but I thought I'd better let other readers know who Raj is and why I emailed him. :slight_smile:
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
