another issue that came up with JDBCConfig is that we found it breaks when dealing with derived properties.
There are two types of derived properties:
- computed ones, that lack a getter, such as “prefixedName()”
- delegated ones, that lack a field, and point directly to the value in another object, for example LayerInfo enabled/advertised
For the derived ones, I wanted to use PublishedInfo/LayerInfo/LayerGroupInfo/.prefixedName… but JDBCConfig does not
see it, because it does not have a getter, whilst it sees the ResoruceInfo one because there is a deprecated getPrefixedName()
method.
For the time being, to move forward, I’ve added getPrefixedName() to PublishedInfo too (and subclasses), but I guess it would
be best if we had a way to declare these derived properties that only have a getter, to allow filtering/sorting on them.
Maybe we could have a derived_properties.properties, in the same spirit as nested_properties.properties?
The delegated ones are nasty… JDBCConfig saves LayerInfo enabled/advertised in the db at the time of import,
and then the GUI only touches ResourceInfo advertised/enabled, so the code saving them only saves the change
in ResourceInfo, but not in LayerInfo.
For these it would be nice to just have nested_properties.propertise handle the case such as:
LayerInfo.enabled=ResourceInfo.enabled
LayerInfo.advertised=ResourceInfo.advertised
since in the end we are accessing a nested property.
One final nasty case is title, which is exposed as a property in PublishedInfo, and it is direct in LayerGroupInfo,
but when it comes to layers, there is a direct property that is never used, and we actually live off the title of the nested
resource.
I guess a delegation declaration such as:
LayerInfo.title=ResourceInfo.title
would do the trick, and we can kill LayerInfo own title? It does not seem anything is using it anyways
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
