Hi folks,
So I spent some time writing developer docs for trunk today, and wrote up developer notes about the web ui with a short tutorial. I would provide the link but docs.geoserver.org seems to be down
Regardless, in doing so I found my self wanting a feature again with sphinx that was a feature I always wanted out of confluence as well: The ability to reference code directly out of svn instead of copying it manually into a code block.
I have looked for the ability to do this in sphinx, and it seems this sort of feature is only supported with python. Boo. The closest thing I have found is the "literalinclude" directive:
http://sphinx.pocoo.org/markup/code.html?highlight=literalinclude#dir-literalinclude
Which is almost exactly what I want, however it requires files to be local. It might work mucking with file paths referencing into the source part of the tree via an external link... but that seemed hacky and external links are painful.
So I decided to look into the sphinx extension system to see how hard it would be to write a plugin that did this. And I met with some success. I created an custom directive called "gsinclude" which basically looks like this:
.. gsinclude:: CatalogInfo
:module: main
:package: org.geoserver.catalog
And the result looks like the following:
http://skitch.com/jdeolive/bs723/skunkworks-v1.0-documentation
And it works with all the line filtering goodness as well:
:module: main
:lines: 15-18
Leads to:
http://skitch.com/jdeolive/bs727/skunkworks-v1.0-documentation
Fun stuff. What I am wondering is what other people think about this sort of custom extension? Useful at all?
It is also very possible that the sphinx gurus out there have a better way to solve this, so I am all ears if they do. But a good exercise none the less to become familiar with some the internal workings of sphinx.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
