in the security implementation work I have to create a ton of wrappers.
These classes are needed in order to make the current user do only
what he's supposed to do, that is, if the current user can only read
a feature type, the wrappers make sure the service really see a read only object, be it a FeatureTypeInfo, a FeatureSource, DataStore,
FeatureCollection and whatnot (man, too many ways to get a write
enabled object!).
On the outbound this works fine, but it might happen some of these
object to come back and be used to query, before passing them
to the actual catalog, unwrapping is needed (since the catalog is
working on object identity comparisons, we have no real "keys"
around).
The java.sql.Wrapper interface is an inspiration, but there are
a couple of gotchas:
(http://java.sun.com/javase/6/docs/api/java/sql/Wrapper.html)
* it is in the wrong package (what I'm doing has nothing to do
with sql)
* it is in the wrong JDK (1.6 onwards)
What about implementing it in GeoTools instead? We could benefit
from using it in the many wrappers we have around (it would
make it possible to walk them for example).
The Wrapper javadoc is also lacking about best practices on
how to implement the wrappers:
* what about equality, when are two wrappers equal? When
they have the same delegate? Or when unwrap(targetClass)
returns the same object (deep or shallow equality?)
* what about hashcodes, shall we use the one of the delegate
or create a new one?
Also wrapper creation is not trivial when two objects
candidate for wrapping point one to the other, like
FeatureSource and DataStore. By using just constructors
to create the wrappers, new wrappers can be created each
time a certain object, say a DataStore, is required, and
that _might_ break some code.
Should we use a factory and a canonicalizer (a weak
hash map using the delegate as the key) to avoid that?
Or I'm just thinking too much? (probably so!).
