[Geoserver-devel] Funny requests sending the dispatcher belly up
recently I’ve been wrestling with QGIS sending really funny requests to GeoServer, that are causing
a not so nice ClassCastException. Here is a sample, it’s a POST request at this URL:
http://host:port/geoserver/ows?service=WFS&version=1.0.0&request=GetFeature&typename=wfs_services:NykoebingFalster_Nordre_Gravsted&srsname=EPSG:25832&&SERVICE=WFS
with body:
<?xml version='1.0' encoding='UTF-8'?>
GEOLOC</Name](http://www.opengis.net/wfs">GEOLOC</Name)>
<gml:Polygon srsName=“EPSG:25832”>
gml:outerBoundaryIs
gml:LinearRing
<gml:coordinates cs=“,” ts=" ">684597.32496083003934473,6074046.84533082041889429 684599.65853476000484079,6074045.35563404019922018 684600.50785672001075,6074046.60537965968251228
684596.93145069386810064,6074050.5842448528856039 684597.32496083003934473,6074046.84533082041889429</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
See how the beast is setup? In the URL we have a valid GetFeature, but the body is a valid Transaction. The dispatcher parses the Transaction
as the request parameter for the service, but then decides to dispatch it to the getFeature method of DefaultWebFeatureService and… boom.
I looked at the code and found that the service/version/method found in the body are ignored if some are found in the URL:
https://github.com/geoserver/geoserver/blob/master/src/ows/src/main/java/org/geoserver/ows/Dispatcher.java#L493
So I said, surely if we have a body in OGC request we should be trusting the body over the URL, no? No… that breaks a test for a old WMS
extension we have supported since… dunno when, but longer that I’ve been around in GeoServer:
https://github.com/geoserver/geoserver/blob/master/src/wms/src/test/java/org/geoserver/wms/wms_1_1_1/GetMapIntegrationTest.java#L545
See? In this case the service/version/method are coming from the URL and the body is just a style object… so in this case we cannot trust
the body, the request is actually fully coming from the URL.
As usual I’m not inclined to break backwards compatibility, so I would like to propose the following, trust the body if possible, but
if we find out that the method being request (matching the root element name) does not exist, then we circle back and see if we can
trust the information in the URL instead.
Opinions? I have a tentative patch I can share (no tests yet, of course I’ll write some if nobody asks for changes):
https://github.com/aaime/geoserver/commit/88d5de5da7f48f87ab0367462116f725960478ab
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On vendredi 2 décembre 2016 17:52:37 CET Andrea Aime wrote:
this URL:
FYI, I’ve been emailed about the same issue but from the perspective of QGIS. Ultimately, this should be fixed in QGIS since such requests are wrong and I wouldn’t expect a WFS server to make sense of them.
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
On Fri, Dec 2, 2016 at 6:19 PM, Even Rouault <even.rouault@anonymised.com>
> Hi,
> recently I've been wrestling with QGIS sending really funny requests to
> a not so nice ClassCastException. Here is a sample, it's a POST request
at
> this URL:
FYI, I've been emailed about the same issue but from the perspective of
wrong and I wouldn't expect a WFS server to make sense of them.
Interesting... wondering how you're going to implement that? Like, wiping
out everything past the ? won't work with mapserver, that
normally needs a reference to a mapfile.
But maybe just removing service/request/version would do the trick.
Do you already know in which version of QGIS the fix will land?
Ing. Andrea Aime
@geowolf
Technical Lead
On vendredi 2 décembre 2016 18:22:38 CET Andrea Aime wrote:
On Fri, Dec 2, 2016 at 6:19 PM, Even Rouault even.rouault@anonymised.com
at
this URL:
Interesting… wondering how you’re going to implement that? Like, wiping
out everything past the ? won’t work with mapserver, that
There are 2 issues in fact:
  • &SERVICE=WFS is always appended at the end of the URL, which is not necessary (but probably not critical)
  • the other parameters come from the user. In past QGIS versions, folks used to put full GetFeature queries (or at least something with VERSION & SRSNAME), so some sanitizing is necessary in that case. But yes I would strip SERVICE, REQUEST, VERSION, TYPENAME(s), SRSNAME, anything that is a WFS KVP.
I’m not sure. Perhaps this can be addressed during the next sponsored QGIS bugfixing session. A first step would be to have a ticket in the QGIS tracker about that.
Even
I kind of agree with Even in that this request is bogus and really does seem like it should be fixed on the sender side. That said the patch doesn’t seem too invasive so looks like a sensible solution to me as well. The worry is that if the dispatcher starts to try to accommodate these kinds of client bugs and peculiarities how far down that rabbit hole will one go :slight_smile:
$0.02
On Fri, Dec 2, 2016 at 6:19 PM, Even Rouault <even.rouault@anonymised.com> wrote:
this URL:
Interesting… wondering how you’re going to implement that? Like, wiping out everything past the ? won’t work with mapserver, that
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Dec 2, 2016 at 6:31 PM, Even Rouault <even.rouault@anonymised.com>
- &SERVICE=WFS is always appended at the end of the URL, which is not
- the other parameters come from the user. In past QGIS versions, folks
WFS KVP.
Agreed, good thinking.
I'm not sure. Perhaps this can be addressed during the next sponsored QGIS
tracker about that.
If the patch I am proposing gets in, the compatibility between the two
systems could be addressed by Dec 18th with the 2.10.1 release.
The trouble being, that it's hard to update a lot of QGIS installations,
compared to a single GeoServer one (referring to an organization
using both, WFS-T is normally not offered to the wide public).
Ing. Andrea Aime
@geowolf
Technical Lead
Pull request here: https://github.com/geoserver/geoserver/pull/2010
Would be nice if we could get these fixes in 2.10.1
On Fri, Dec 2, 2016 at 6:32 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
$0.02
On Fri, Dec 2, 2016 at 10:24 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
engaging tech sites, SlashDot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Geoserver-devel@anonymised.comsourceforge.net
this URL:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
